Lincoln Y-Block Question oil drive shaft length
Posted By ratfink1973 8 Years Ago
ratfink1973
Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)
Posts: 3, Visits: 3
Hello, my name is Dieter and i am from Austria. I have an Lincoln Capri 4 door sedan from 1953. In the last years i change a lot of parts on it. The last parts where the distributor( now from a Ford y-block from 1962-63, oil pump carburetor and the drive shaft. Now i had the problem that the drive shaft is too short. I ordered 8.06 1/4 hex and i need a longer one. Could anyone say me the correct length that i need?
Is 9.16 enough for that pump and distributor?
Regards from Austria Dieter
PS: i hope my english is not too bad
Last Active: 5 days ago
Posts: 7.4K, Visits: 205.0K
The Melling oil drive I have here (#IS-60A) for the 1956-1963 302/332 LYB engines measures out at 9.167” overall length.  Not sure if that particular unit is the same length as the other LYB engines with the hex drive oil pump but I expect it to be the same.
Bobwanna
Supercharged (309 reputation)Supercharged (309 reputation)Supercharged (309 reputation)Supercharged (309 reputation)Supercharged (309 reputation)Supercharged (309 reputation)Supercharged (309 reputation)Supercharged (309 reputation)Supercharged (309 reputation)
Posts: 108, Visits: 5.8K
Hello Dieter, Welcome to Y-Blocks Forever. We do have a few experts here that can answer questions on the LIncoln engine. The Capri is a very nice looking car. - Bob
AKA   Bob-93021
ratfink1973
Posts: 3, Visits: 3
Hello, thank you for the answers. I ordered the new drive shaft and hope that i get it soon.
Could you say me some adress for Lincoln parts?
I need also a repair kit for the power steering pump.
Regards Dieter
ratfink1973
Posts: 3, Visits: 3
No ideas?
stuey
Supercharged (851 reputation)Supercharged (851 reputation)Supercharged (851 reputation)Supercharged (851 reputation)Supercharged (851 reputation)Supercharged (851 reputation)Supercharged (851 reputation)Supercharged (851 reputation)Supercharged (851 reputation)
Last Active: 6 days ago
Posts: 440, Visits: 3.8K
what sort/make of pump?
stuey
UK
Oldmics1
Supercharged (152 reputation)Supercharged (152 reputation)Supercharged (152 reputation)Supercharged (152 reputation)Supercharged (152 reputation)Supercharged (152 reputation)Supercharged (152 reputation)Supercharged (152 reputation)Supercharged (152 reputation)
Posts: 50, Visits: 9.6K
Contact these folks
http://www.lincolnoldparts.com/
They should be able to help.
Oldmics
