By ratfink1973 - 8 Years Ago
Hello, my name is Dieter and i am from Austria. I have an Lincoln Capri 4 door sedan from 1953. In the last years i change a lot of parts on it. The last parts where the distributor( now from a Ford y-block from 1962-63, oil pump carburetor and the drive shaft. Now i had the problem that the drive shaft is too short. I ordered 8.06 1/4 hex and i need a longer one. Could anyone say me the correct length that i need? Is 9.16 enough for that pump and distributor? Regards from Austria Dieter PS: i hope my english is not too bad
By Ted - 8 Years Ago
The Melling oil drive I have here (#IS-60A) for the 1956-1963 302/332 LYB engines measures out at 9.167” overall length. Not sure if that particular unit is the same length as the other LYB engines with the hex drive oil pump but I expect it to be the same.
By Bobwanna - 8 Years Ago
Hello Dieter, Welcome to Y-Blocks Forever. We do have a few experts here that can answer questions on the LIncoln engine. The Capri is a very nice looking car. - Bob
Hello, thank you for the answers. I ordered the new drive shaft and hope that i get it soon. Could you say me some adress for Lincoln parts? I need also a repair kit for the power steering pump. Regards Dieter
No ideas?
By stuey - 8 Years Ago
what sort/make of pump? stuey UK
By Oldmics1 - 8 Years Ago
Contact these folks http://www.lincolnoldparts.com/ They should be able to help.
Oldmics
