Visits: 137.8K
Take the time to take it apart and fix it right the first time. You will end up taking it apart anyway.
Visits: 32.6K
When I had trouble trying to fix a small Leak at the Stat Housing I ended up cutting a new Gasket from a sheet of thicker Gasket Material using the original Gasket a a Template. Been together for 5 Years with no further Leaks.
Visits: 190.0K
do not put any of that crap in the cooling system,it plugs rad tubes and will most likely not stop the leak. just fix the leak with a new gasket and be sure surfaces are straight
Visits: 22.0K
The Barrs Leaks powder will prolly work for a small leak like that. Generous Motors installed it on the assembly line for several years and may still be doing it. Some old timers would just dump a small can of black pepper in the radiator with the engine running and warmed up. I don't think I'd try anything more aggressive than that.
Last Active: 22 minutes ago
Posts: 3.6K,
Visits: 497.7K
I have a very small leak at the thermostat housing and would like to try a sealer before pulling it apart. Any recommendations on a sealer?
