speedpro56
Posts: 1.3K,
Visits: 9.2K
NEWS FLASH !!!!!  Looks like Aluminum cylinder heads are going to be a reality according to John Mummert y-Block in El Cajon Ca. spread the NEWS!!!!!!!
-Gary Burnette-
That's great! Do you have any details? When available? Out-of-the-box performance target?
speedpro56
Posts: 1.3K,
Visits: 9.2K
In a few weeks he hopes to have a few prototype castings. They can be had complete or you can do your own work. As for me I'll go with the complete setup that will bolt on.
-Gary Burnette-
Larry D
Visits: 1.4K
Wonderful news! The last set of ECZ heads I did for my 312 street motor have over $2,400 in them. An out of the box aluminum set for around the same money would be an easy purchase.
Larry D
Winnipeg, MB Canada Eh!
'58 Custom 300 Tudor
'56 Crown Victoria
'61 Starliner Z Code
'51 Ford Victoria
BFOOTER03
Last Active: 14 Years Ago
Visits: 1.2K
Great news!!! Keep us posted.
Warsaw, IN
davis
Visits: 687
keep us posted, and post pics when available.
i wouldnt be surprised if they are 3k a pair out of box.
larry, $2,400 an easy purchase?
wish i had deep pockets.
This ain't no L-Kamino!
Moz
Visits: 3.7K
guys i have a question has anybody thought about electrolysis between the aluminium heads & cast iron blocks something us y-blockers have never needed to worry about
 moz. geelong victoria australia. graduate 1980, bus, truck, car, hot rod, boat, submarine, hovercraft, hydrafoil, firetruck, mobile home, jet, helicopter, cruise ship, motorcycle, bicycle, santa's sleigh, clock, alloy bullbar, alloy fuel tank, lens, dr who's tardis, matter - anti matter warp drive buffer & y-block lover
bird55
Posts: 1.1K,
Visits: 58.8K
Hey Moz, Pegleg knows the answer to your question-he can enlighten us all.
Posts: 3.0K,
Visits: 8.7K
Moz, They make additives to control that, Modern antifreeze will stop it too. Y blockers that had the dual quad setups in '56 and '57 E codes had the problem with the intake. The alloy and heat treat that John will use is going to be much better at resisting the corrosion than what was available 50 years ago. Have not had any problem with the aluminum Water pumps or Timing covers..........YET! Just about every car on the road any more has aluminum and iron castings together.
Moz
Visits: 3.7K
frank thats good to know maybe john could teach the japs this or maybe geelong water is too hard our alloy heads are always causing problems one of (& this is sacralidge) our ford 6 cyl heads used to grow 1/2 an inch
