short rear end
Posted By funkydude 8 Years Ago
funkydude
Supercharged (89 reputation)Supercharged (89 reputation)Supercharged (89 reputation)Supercharged (89 reputation)Supercharged (89 reputation)Supercharged (89 reputation)Supercharged (89 reputation)Supercharged (89 reputation)Supercharged (89 reputation)
Posts: 28, Visits: 2.8K
A friend has a 1950 Ford and is looking for (any) rear end that is no wider than  (outside to outside)  55 5/8".  Can anyone help him?  Thank you
Rowen
Posts: 435, Visits: 29.3K
I see on eBay, (seller, pemracing (1401), they have them 54"-56" wide. Complete with axels, bearings, seals, etc., for about $600-$800 bucks. Beyond that....someone else most likely has a better source..
Rowen
55CV
Woodland, Ca
Last Active: 27 minutes ago
Posts: 4.6K, Visits: 38.4K
Early Mustang, 57 Ford, or you can also use early Bronco but they are 5 on 5.5" so you will need wheels to fit adapters or aftermarket axles. The axles are around $300 a pair. Sometimes its just easier to buy a complete sized to fit rear from places like Speedway.
http://www.fordmuscle.com/archives/2002/02/nineinch/
slumlord444
Posts: 1.2K, Visits: 137.8K
I don't have the exact measurements but '57-'59 Ford should fit. I know they fit in a '55-56 Ford. '59 and '53 wheels interchange because I did it in High School. I think '50 had the same bolt pattern but not certain.
Dave V
Supercharged (459 reputation)Supercharged (459 reputation)Supercharged (459 reputation)Supercharged (459 reputation)Supercharged (459 reputation)Supercharged (459 reputation)Supercharged (459 reputation)Supercharged (459 reputation)Supercharged (459 reputation)
Last Active: 9 hours ago
Posts: 234, Visits: 41.4K
Where are you located? I have a complete rear in a 56 car that I'm going to replace with a 9" Ford. I'm in SE Wis,. Dave
SE Wis
carl
Posts: 1.2K, Visits: 20.6K
funkydude (3/14/2017)
I have not measured this rear end but I have a 56 Ford wagon (dana 44) that is complete for sale,i will check the demitions tomorrow.Located in central ohio  Carl
Small block
Posts: 90, Visits: 2.5K
The narrowest rear you will find in a Ford is the  Maverick  and that is 56.5 drum to drum.
The 1965 mustang  is the same as a 1957 ford at 57.25 drum to drum!
To get narrower than that  you would have to have a housing and axels  narrowed!
Small block
       One possibility would be   use the wider diff with a set of the  negative  offset Wheels like the  modern  Cars use!
dbird
Posts: 279, Visits: 4.0K
It takes some work, but Volvo guys are using 8.8 Ford diffs by shortening the tube on the long axle side to match the short side and using a short axle in both sides.  I don't know what the final width is, but a Volvo 244 has a rear track of about 53 inches.  The axle tubes are just pressed into the center section then pinned.  I probably didn't explain it all that well, but a quick search of Ford 8.8 in Volvo brings up plenty of discussion.  Not as strong as a 9 inch, but close and cheap.  I bought one for my F100 at Pick and Pull for about $150 out of an Exploder with 3.73s, posi, and disc brakes.
Don
