Engine not starting after rebuild
Posted By dennis22 8 Years Ago
dennis22
Supercharged (428 reputation)Supercharged (428 reputation)Supercharged (428 reputation)Supercharged (428 reputation)Supercharged (428 reputation)Supercharged (428 reputation)Supercharged (428 reputation)Supercharged (428 reputation)Supercharged (428 reputation)
Last Active: 8 Months Ago
Posts: 166, Visits: 59.7K
I have put my 272 Y block back together after a rebuild, only to come to break-in and she won't start. Just seems like a timing problem. As I don't know too much I'd thought I'd try the collective knowledge of you y blockers.
Now regards to ignition/timing, I have a new cam, valve springs, timing set, crank dampener and MSD distributor and coil and new leads and plugs.
Bit of insight-
I set #1 piston at TDC compression stroke and counted 12 pins between timing chain marks. The new dampener's timing marks also correspond to #1 TDC. So at this stage I'm looking good. I marked where I wanted #1 lead on my dizzy cap, transferred it down and dropped the dizzy in with the rotor pointing a #1. I then cranked the engine by hand until piston #1 was at compression TDC and checked rotor was still pointing at #1. All good.
After checking a few thinks I tried to start the engine... I threw a tiny bit of fuel in the carby and cranked her over. Nothing- kept cranking until fuel was fully primed in carby. I then left it for 15mim to think and tried again, still nothing but a couple of coughs.
I'm not sure if it has anything to do with the new MSD dizzy and coil or something I have done wrong.
Any help would be appreciated. Thanks, Dan.
Thanks, Dennis.
56 F100 - 272 Y Block
NSW, Australia.
Threaded View
Threaded View
Forum Post Engine not starting after rebuild By dennis22 ( 8 Years Ago )
Forum Post Were the timing marks on the crank, cam, to your right while standing... By ponymare ( 8 Years Ago )
Forum Post How did you determine it was on the compression stroke? Could be 180... By 57RancheroJim ( 8 Years Ago )
Forum Post If you determined that number 1 is on compression while installing the... By charliemccraney ( 8 Years Ago )
Forum Post I hope the 12 pins and marks were on the right, the Eckman book is... By kevink1955 ( 8 Years Ago )
Forum Post It's referring to the left side/bank of the engine not your left hand.... By 57RancheroJim ( 8 Years Ago )
Forum Post It's not going to start because you painted it the wrong color. :D... By 56_Fairlane ( 8 Years Ago )
Forum Post Don't believe him Dennis, mines that color and it starts just fine.😀 By miker ( 8 Years Ago )
Forum Post Dennis22, another thing to check is to be sure the plug wires are... By BamaBob ( 8 Years Ago )
Forum Post Ok, so I'll try to answer everyone- Ponymare- yep the timing marks... By dennis22 ( 8 Years Ago )
Forum Post If you are starting the engine on an engine stand, do you have the... By Joe-JDC ( 8 Years Ago )
Forum Post Joe- The engine is on a stand and the battery is grounded to the... By dennis22 ( 8 Years Ago )
Forum Post Just checked #1 and #4 for compression and got this reading. This... By dennis22 ( 8 Years Ago )
Forum Post Thanks for the picture of the bell housing, it just didn't look like a... By 57RancheroJim ( 8 Years Ago )
Forum Post 57RancheroJim- i didn't have the carb wide open. I did pull #1 plug... By dennis22 ( 8 Years Ago )
Forum Post A red hot starter and a dead battery is a sign of very high friction,... By miker ( 8 Years Ago )
Forum Post OK Miker, I'll get that trans off and see what happens (hopefully that... By dennis22 ( 8 Years Ago )
Forum Post Did you prime the oiling system? No matter what the answer, it will... By charliemccraney ( 8 Years Ago )
Forum Post Charliemccraney- I did prime the oil system using a drill an an old... By dennis22 ( 8 Years Ago )
Forum Post Dennis, From all that I have read here, it seems to me that the... By BamaBob ( 8 Years Ago )
Forum Post [quote][b]BamaBob (2/14/2017)[/b][hr] Dennis, From all that I... By dennis22 ( 8 Years Ago )
Forum Post I can't picture how a trans and clutch would go together if it was... By 57RancheroJim ( 8 Years Ago )
Forum Post The trans shouldn't have been hard to get in once aligned. Perhaps... By MoonShadow ( 8 Years Ago )
Forum Post I just finished a 312 engine rebuild start on stand. My starter that... By YBLOCKEREDH ( 8 Years Ago )
Forum Post glad it all worked out.tho i am sure if you had primed the intake with... By 2721955meteor ( 8 Years Ago )
Forum Post Still doesn't explain why a new starter would crank 20 times faster, I... By YBLOCKEREDH ( 8 Years Ago )
Forum Post [quote][b]YBLOCKEREDH (2/14/2017)[/b][hr] I just finished a 312... By dennis22 ( 8 Years Ago )
Forum Post Hi Dennis, All things considered, I think you are on the right track... By BamaBob ( 8 Years Ago )
Forum Post Hello Dennis, I was looking over your earlier posts you mention... By YBLOCKEREDH ( 8 Years Ago )
Forum Post Ok, update time.... So my starter arrived today from Dennis carpenter... By dennis22 ( 8 Years Ago )
Forum Post [quote][b]dennis22 (3/4/2017)[/b][hr].....So in the end all it needed... By Ted ( 8 Years Ago )
Forum Post If that is 30 to 40 degrees at a normal idle speed, then yes, it is... By charliemccraney ( 8 Years Ago )
Forum Post Thanks Ted, Yep first mistake- timing was with vacuum on and I forgot... By dennis22 ( 8 Years Ago )
Forum Post [quote][b]dennis22 (3/4/2017)[/b][hr]....Also the dampener is brand... By Ted ( 8 Years Ago )
Forum Post [quote][b]charliemccraney (3/4/2017)[/b][hr] If that is 30 to 40... By dennis22 ( 8 Years Ago )
Forum Post Charlie thanks mate, as I said to Ted I was a bit excited and bungled... By dennis22 ( 8 Years Ago )
Forum Post Ok, so I checked the timing again. -I pulled the vacuum advance off... By dennis22 ( 8 Years Ago )
Forum Post That is probably an electronic version of a dial back timing light Ted... By charliemccraney ( 8 Years Ago )
Forum Post Thanks for the info Charlie. So if I set no1 piston at TDC and TDC on... By dennis22 ( 8 Years Ago )
Forum Post Refer to the instructions to understand how to use the timing light.... By charliemccraney ( 8 Years Ago )
Forum Post Degreeing a cam was always a "black art" to me. Once I learned by... By DryLakesRacer ( 8 Years Ago )
Forum Post What heads are on this engine? By Sandbird ( 8 Years Ago )
Forum Post The heads are mismatching at the moment. I'm trying to track down... By dennis22 ( 8 Years Ago )
Forum Post It would be interesting to see what the cranking compression is on the... By Sandbird ( 8 Years Ago )
Forum Post That is quite a mis-match with the heads. It will be impossible to... By charliemccraney ( 8 Years Ago )
Forum Post Charlie, I asked this question a while back, seems that in the short... By dennis22 ( 8 Years Ago )
Forum Post Dennis: I don't know if you'd want to pay the shipping..but a possible... By PF Arcand ( 8 Years Ago )
Forum Post If you caught my earlier post about the water leak- you may already... By dennis22 ( 8 Years Ago )
Forum Post Hi Dennis,15/16 hg of vacuum with a non stock cam is ok at idle,but... By chris70 ( 8 Years Ago )
