T 5 conversion in a 55 customline
Posted By fastbillsgarage 8 Years Ago
fastbillsgarage
Supercharged (97 reputation)Supercharged (97 reputation)Supercharged (97 reputation)Supercharged (97 reputation)Supercharged (97 reputation)Supercharged (97 reputation)Supercharged (97 reputation)Supercharged (97 reputation)Supercharged (97 reputation)
Posts: 36, Visits: 59
I re-read petew's install link that charlie mcraney posted. Pete covered the install very well and I don't see any need really to go over how I did mine all over again except to maybe touch on the few things I did differently or offer a few tips. My car is kinda rough and is daily driven so forgive some of my pics if it's not all that pretty. One of the things you have to do for the swap is shorten the input shaft. For backyard types like me, I put a yoke in the tailshaft, put a ratchet through the yoke, put the trans in gear and had someone rotate the output shaft while I ground on the input shaft. I know that seems sketchy, but I did it a little bit at a time so as not to create a lot of heat at once. This also let me recreate a consistent bevel on the end like it originally had. p
fastbillsgarage
Once I had the trans in after much grinding and trying and grinding on the input shaft because I didn't want to grind too much, I fabbed this transmission crossmember. It uses the factory holes in the frame and the stock mustang transmission mount. I actually made two of these. One is in the car and the other is so I'll have a model to duplicate from if you guys have any interest in these. My car is a 55. I imagine that a 56 and possibly t-birds would be the same. I've been driving the car for a few weeks now. Everything seems to be rocking on just fine!
fastbillsgarage
The underside of the trans crossmember
fastbillsgarage
Like I said, my car is a daily driver work in progress so forgive the ratty interior. It'll be nice one day. I chose to use a shifter from summit. It's a generic summit brand billet shifter for mustang T5 for about $140. It may be Chinese, I don't know, the box says made in USA and it looks like a quality product. The reason I chose it is because it had adjustable stops. I didn't order a shift handle until I'd finished the job because I wasn't sure where it was going to come up through the floor. I didn't want a potentially long shift handle applying excessive pressure on the forks and wearing them out prematurely. So, once I saw where the handle came out I got on the Core shifters website and ordered the Hurst shifter handle I liked which bolts right up. In the pic I have the stock bench seat in the rearmost position and the shifter is in neutral. I'm 6'1” so my seat is staying there haha. Looking at it now with the shift handle I got, I think it might be for a truck but I'm happy with it. I don't think it looks rat roddish (which I hate). I can shift through all the gears while sitting upright and no leaning forward for the upper gears. Plus once it's in 5th I still have room for a female to sit close. Now that I have done this setup, I don't feel that the shifter with adjustable stops was quite so necessary. Especially if you're going to use a shorter stick.
fastbillsgarage
Forgot to include a pic of the crossmember installed. Crude pic, I don't have a lift yet so undercar pics are tricky.
Nice job on the crossmember.  The only thing I'd do differently is put the bolt holes on the side opposite the tubing weld seam. Wink
If you have not already, smooth that seam so that the washers and bolts clamp properly.
fastbillsgarage
Charlie you're a sharp fella to catch that! hahahah. I agree with you and I caught that during the build process. the black one in the car has the seam on the right side, the bare metal one is the model to duplicate from. good catch sir!
petew
Supercharged (306 reputation)Supercharged (306 reputation)Supercharged (306 reputation)Supercharged (306 reputation)Supercharged (306 reputation)Supercharged (306 reputation)Supercharged (306 reputation)Supercharged (306 reputation)Supercharged (306 reputation)
Posts: 178, Visits: 5.0K
Nice job Bill, the best part is yet to come that being driving the finished product.
