75 to 80 all day long
Posted By junkyardjeff 10 Years Ago
junkyardjeff
Posted 10 Years Ago
Posts: 813, Visits: 3.4K
Right now my sunliner has a 351-W and just got back from a trip to Florida yesterday going 75 to 80 all the way there and back and that got me wondering will a Y block be able to do that too,I had never driven a older motor like that before so I do not know what to expect. I do plan on keeping the gears to around 3.00 and most likely have a FMX trans,I do plan on building another car to do these long distance trips (one I can lock up) with the 351 but still would like to take the sunliner on some long trips. I like to get where I am going quickly.
62bigwindow
Posted 10 Years Ago
Posts: 884, Visits: 14.3K
I don't think it would be a problem. My 56 with a overdrive trans can do 70 without any issues.
Durham Missouri
Posted 10 Years Ago
It will be able to do that easily.
Posted 10 Years Ago
Posts: 7.5K, Visits: 205.9K
See if this helps to answer your question.
http://forums.y-blocksforever.com/Topic121710.aspx
junkyardjeff
Posted 10 Years Ago
Even though I had many old cars over the years I never really drove them hard like I did with the latemodels and never drove them more them maybe 125 miles each way,the sunliiner is the first I have driven very far but does have a newer motor in it so I would still like to take it on long trips after it gets y block powered again.
Posted 10 Years Ago
Posts: 3.7K, Visits: 497.9K
I've made two trips across the US in my 56 Bird with a 312 and an automatic (1 st with a Fordo, the second with a C4).  RPM's were about 2800.  We traveled most of the day as 65- 70 MPH.  The engine was none of the worse for doing it.  The engine runs great.  I don't know what the mileage is on it (replalcement block when I got it) but the only thing I did was replace the heads with a original set (had later heads on it) because of valve inversion..
Posted 10 Years Ago
While the 351 is newer, I think it is a stretch to call it modern, even in comparison to a Y.  A 351 is more or less the  same technology as a Y but in a different configuration.  Bottom line, if the Windsor can do it, then the Y Block can, and vice versa.  There may be some improvements (some may argue downgrades) but they are not leaps and bounds better.
The significant benefit of the small block is IF you have problems, you'll be able to get parts more easily in an emergency situation.
junkyardjeff
Posted 10 Years Ago
All the drivetrain is older then 30 years old but rebuilt,the 351 is a mid 80s motor and the trans is a mid 70s c-4 and the 8 inch is from a 75 maverick so nothing is modern.
speedpro56
Posted 10 Years Ago
Posts: 1.3K, Visits: 9.2K
I've driven these yblocks hundreds of thousands of miles and they stand up to any of my so called modern engines at any speed long or short distances. When I bought my 1956 Sunliner in 1974 stock 292 Fordo tranny I drove it to Myrtle Beach S.C. and back to Asheville, N.C. 300 miles each way 70 to 80 mph steady. The car had been setting for 15 years when I bought it and sound great when Started and a new set of mufflers. After new brakes, hoses, belts, tires she was ready to go, and go she did and what a great time I had with the top down.
-Gary Burnette-
DANIEL TINDER
Posted 10 Years Ago
Posts: 1.7K, Visits: 154.3K
62bigwindow (11/30/2016)
Since many interstate speed limits have been raised to 70 or 75, most traffic now cruises at 80, and thus the police would be unlikely to bother anyone not exceeding 85. My stock/high-mileage '55 with OD easily stays with that flow, though kicking down to underdrive for passing at that speed sometimes DOES approach my rev limit before I return to the right lane.
50s era vehicles were really not designed to maintain those speeds continuously, and while modern radial tires can now make it practical, the fact that the personel, equipment and parts to keep the original drum brakes up to the tire's potential no longer exist, worries me much more than any question re: the sturdy Y-Block's reliability or ability to absorb punishment. I understand the high-torque 292 powered very many commercial trucks for multiple hundreds of thousands of miles with few issues. I don't believe the thin cast Windsor (or sbc) would quickly come to mind when listing famous 'truck engines' (?).
6 VOLTS/POS. GRD. NW INDIANA
