steering wheel for 56 Ford VicI
Posted By John Del Bene 20 Years Ago
John Del Bene
Posted 20 Years Ago
Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)
Last Active: 17 Years Ago
Posts: 10, Visits: 232
I would like to put 1966 Galaxie steering wheel on my 56 Ford Vic. Will this fit? I sure hope so!Smile
Posted 20 Years Ago
Posts: 3.7K, Visits: 323.4K
John:
The wheel will probably fit the splines, I put a '71 Bird wheel on my '57.  However the horn circuit will be different, the '56 has a wire through the hollow steering shaft, the '66 will have a horn brush arrangement in conjunction with the turn signal switch.  The turn signal cancelling cam arrangement is probably different also.
John
