steering wheel for 56 Ford VicI
http://forums.y-blocksforever.com/Topic1269.aspx
By John Del Bene - 20 Years Ago
I would like to put 1966 Galaxie steering wheel on my 56 Ford Vic. Will this fit? I sure hope so!Smile
By Hoosier Hurricane - 20 Years Ago
John:
The wheel will probably fit the splines, I put a '71 Bird wheel on my '57.  However the horn circuit will be different, the '56 has a wire through the hollow steering shaft, the '66 will have a horn brush arrangement in conjunction with the turn signal switch.  The turn signal cancelling cam arrangement is probably different also.
John
