Last Active: 4 Months Ago
Visits: 137.2K
Had them off of my T Bird a while back. No problem. Now I have gone brain dead and can't seem to figure out how they come off. Know I did it without any special tools. Couldn't find it in the shop manual. Anyone?
Last Active: 11 hours ago
Visits: 144.1K
I know they make a special tool, but a rag and a wide/progressive size selection of straight edge screwdrivers will work. The real trick is getting the register correct when reinstalling. Good luck.
6 VOLTS/POS. GRD. NW INDIANA
Visits: 137.2K
Finally looked at it and cussed it long enough to figure it out. You were right. Needed a bigger screwdriver. When I am in the mood to tinker I will make a tool to do this. I'm thinking an old wood chisel that's the right thickness with a slot cut in it to slide under the shaft. May have to heat and bend it to make it work properly.
Visits: 1.9K
Get the tool,,,,,,,,,,JT 85,,,,,,,Snap-On
