Start out at John Mummert's site.
http://www.ford-y-block.com/index.html. Both the timing chain and clutch (in the flywheel section)
Depending on where you are, shipping might be a concern. Others on here, like Ted Eaton, might be able to help as well. All their stuff is first rate.
I'm partial to the basic level CenterForce clutches. They don't show them on the web site, but I'm sure they've got them. Light pressure on the pedal, smooth engagement. Make sure the flywheel surface is true.
