By Sanddoc - 9 Years Ago
sorry to be posting so often, but like it says this is the site for the best info on the Y Block I've searched. So give me some clutch kits for my 292 3 spd out of a F100 I'd like to go above a stock setup on the clutch.. Second. How about a roller timing chain setup thanks Dave
By miker - 9 Years Ago
Start out at John Mummert's site. http://www.ford-y-block.com/index.html. Both the timing chain and clutch (in the flywheel section)
Depending on where you are, shipping might be a concern. Others on here, like Ted Eaton, might be able to help as well. All their stuff is first rate.
I'm partial to the basic level CenterForce clutches. They don't show them on the web site, but I'm sure they've got them. Light pressure on the pedal, smooth engagement. Make sure the flywheel surface is true.
