Is it even possible to finds a complete and working 3 speed o/d these days
Posted By junkyardjeff 10 Years Ago
Is it even possible to finds a complete and working 3 speed o/d these...
Posted 10 Years Ago
Posts: 1.9K, Visits: 195.0K
Ok, that sounds more like it, at least $ wise. I think all 292's came with the T-86 unit, at least my 55 bird did. The T-85 R-11 came behind the 312's, and was used up to the 406's. So it's pretty tough. Unless your foot keeps slipping off the clutch at 5000 rpm or so, a T-86 is fine. Probably lose the rear end first.
62bigwindow
Posted 10 Years Ago
Posts: 884, Visits: 14.3K
As far as replicating the complete system it won't be that hard. The relay and kick down switch are available aftermarket as is the wiring harness and the OD cable. I have a reproduction harness also if you choose. For some reason it wouldn't work on my car. It was a little too short and I didn't feel like moving the relay.
Durham Missouri
62bigwindow
Posted 10 Years Ago
The T86 only came with the R10 overdrive. The Ebay listing is insanely high. A good T86 OD will run around $300 and a T85 OD about twice that. If your motor is stock a T86 OD will live forever as long as you don't routinely abuse it. A higher HP motor that will see abuse would require a T85. If your interested in my T86 OD let me know. It worked great with no problems.
Durham Missouri
Posted 10 Years Ago
Jeff, maybe I'm just out of date, but that's way more than I'd expect for a T-86 R-10. That's even high for a T-85 R-11. I'd keep looking, I think you can do way better than that.
If you get the right one, i.e., not a truck, with the right length input shaft, or whatever, I think about all you'll need is the driveshaft. Maybe a mount change or clutch disc if the splines aren't the same.
The hot rod reverend mocks one up in his "refresh" blog, might try contacting him. He seems to have a line on parts sometimes.
junkyardjeff
Posted 10 Years Ago
Last Active: 5 days ago
Posts: 813, Visits: 3.4K
I would prefer a 56 and up trans since my 55 is now`12 volts and does look like I will be spending big money if I do go with one,since I will be starting from scratch I will need to find one that has everything with it.
62bigwindow
Posted 10 Years Ago
Yes that is correct.
Durham Missouri
Posted 10 Years Ago
Two currently advertised remanufactured T-86 3 speed w/ R-11 overdrive units on eBay.  Intended for information purposes, not mine.
http://www.ebay.com/itm/BORG-WARNER-1967-FORD-T-86-3-SPEED-REBUILT-TRANSMISSION-WITH-R-10-OD-10-X-28-/351738486851?hash=item51e53f6043:g:2-cAAOSwQjZXPg9E&vxp=mtr
http://www.ebay.com/itm/BORG-WARNER-FORD-T-86-3-SPEED-REBUILT-TRANSMISSION-WITH-R-10-OD-NARROW-BOLT-/291510061692?hash=item43df5a8a7c:g:OzoAAOSwv0tVZ3TZ&vxp=m
Notice that the two units have different spline counts on the input shaft.
The seller has had a high number of transactions on eBay (over 5,000) and is carrying a 100% satisfaction rating which is hard to do.  I bought synchronizers (blocking rings) from him and was satisfied with the transaction.
Posted 10 Years Ago
Hmmmm...
Your '56 3 spd. w/ o/d will work in his '55.  All he would have to do is substitute a 6 volt solenoid for the current 12 volt unit.  Everything else is the same    Smile
62bigwindow
Posted 10 Years Ago
There are 2 options. The T86 with the R10 overdrive and a T85 with the R11. The T85 will be a bit tougher to find as they are real popular. I have a T86 with OD that I may sell but it's out of a 56. Unless you plan to convert your car to 12 volt the solenoid won't work.
Durham Missouri
Posted 10 Years Ago
I saaume you're looking for the T-86 and R-10 combo that would have come stock. Post a wanted add here, the ford barn, and maybe the HAMB. Might try eBay also, but I'd want to see it first if it was there.
