Y starter interchange with flathead?
Posted By davis 18 Years Ago
davis
Posted 18 Years Ago
Supercharged (241 reputation)Supercharged (241 reputation)Supercharged (241 reputation)Supercharged (241 reputation)Supercharged (241 reputation)Supercharged (241 reputation)Supercharged (241 reputation)Supercharged (241 reputation)Supercharged (241 reputation)
Posts: 188, Visits: 687
also wanted to know if the Y block starter would interchange with late model flathead.
if i'm converting to 12V, might as well do it all.
thanks!
This ain't no L-Kamino!
Posted 18 Years Ago
Posts: 3.7K, Visits: 323.8K
Davis:
The Y starter mounts with three bolts in the flange at the drive end of the starter.  If I remember correctly, flathead starters mount with two bolts through the starter itself.  The 6 volt wtarter will work on 12 volts, it actually has bigger windings in it that the 12 volt one has.
John in Selma, IN
2DRHRDTP57
Posted 18 Years Ago
Supercharged (213 reputation)Supercharged (213 reputation)Supercharged (213 reputation)Supercharged (213 reputation)Supercharged (213 reputation)Supercharged (213 reputation)Supercharged (213 reputation)Supercharged (213 reputation)Supercharged (213 reputation)
Posts: 207, Visits: 1.8K
Gents,
Isn't the Yblock starter just a flathead starter with a alloy 3 bolt adapter attached by the two original flathead mounting bolts?  is what I was led to believe.
1957 ________________ Ford
\___((_______________))___/
(@)________V__________(@)
[________I_____I_________]
__[__]__ o_______o___[__]___
Y Blocks, The New Flathead!
Posted 18 Years Ago
Dutchy:
I just compared the two, the case lengths are the same, but the Y starter is about 3/4" longer from the back end of the case to the tip of the shaft.  The flathead armature may fit in the Y case though.
John in Selma, IN
2DRHRDTP57
Posted 18 Years Ago
Thanks John,
That myths busted!!!!
Posted 18 Years Ago
Posts: 3.8K, Visits: 33.2K
I don't know if you want to spend this much but I got a flyer from joblot auto(joblotauto.com) in NY and they have brand new(no core required)flathead starters in 6 and 12 volt for $169.00 plus shipping.They also have front control arm kits which do upper and lower arms complete with shafts,all bushings, and lower bolts for $115.00 for 54-56 Ford cars and 55-57 Tbird if anyone is looking for these items.Regards Mark
