Oil drain plug
Posted By MoonShadow 9 Years Ago
Posts: 4.6K, Visits: 38.5K
Just changed pans on my 292 and was surprized to find that the oil drain plug doesn't fit. Its much smaller than the ones I'm used to. More like a 3/8" hole. Any chance of finding on through a parts store? When did they go to the smaller drain plug? Also, I have a gearoter pump I was going to put on but instead of the hex shaft drive is has a tab to fit in a slotted shaft. What is that?
later truck pans use a 1/2"-20 drain plug.  That is a very common size.
The tang drive pump is 1954 only.  There are rebuild kits available from Melling.  If the drive style is the only difference, then that will get you a hex drive and new rotors and relief valve spring.
The pump is a NOS gear rotor aluminum pump. I guess I'll put it out there for the 54 owners. So its 256 or 272? Thanks, Charlie
Posts: 3.7K, Visits: 497.8K
As far as the drain plug, check ebay under Ford oil drain plug.  Lots of options for 1/2 -20 size.
Charlie; The pump you have is for a 239 or 256, not a 272, which takes the common later design.
30 coupe
Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)
Posts: 130, Visits: 3.4K
you can buy a replacement drain plug at NAPA, or O'Rielly's  I bought one recently from O' Rielly's, it was about  $2.50
Thanks all. I did find one at O'rielly's.
