billet aluminum oil filter adapters
Posted By Frederick E. Johnson 9 Years Ago
Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)
Posts: 3, Visits: 9
Hi All!
I am going to install a billet aluminum oil filter adapter on a newly rebuilt 312 and wanted to know how much torque is required and whether the gasket should be installed dry, oiled or with sealer.
2721955meteor
Posts: 927, Visits: 190.0K
would use a sealr,like high ytack in a spray can. besure to toqe the bolt corectley.
Brodie55
Supercharged (138 reputation)Supercharged (138 reputation)Supercharged (138 reputation)Supercharged (138 reputation)Supercharged (138 reputation)Supercharged (138 reputation)Supercharged (138 reputation)Supercharged (138 reputation)Supercharged (138 reputation)
Posts: 62, Visits: 3.3K
The billet adapters I am familiar with just use an o-ring to seal against the block...no gaskets. Just oil the o-ring and torque the fastener.
Posts: 3, Visits: 9
Thanks.
I am assuming it is safe to torque the steel fitting against the aluminum?
Posts: 3.6K, Visits: 497.5K
Did you buy that recently?  I tried to get one, talked to the guy who was making them.  He always had excuses why he didn't have any.  Got tired of chasing him.
Posts: 6.1K, Visits: 441.8K
There are new ones on eBay, http://www.ebay.com/itm/SPIN-ON-OIL-FILTER-ADAPTER-KIT-FOR-Y-BLOCK-FORDS-BILLET-232-252-272-292-312-352-/252447012742?hash=item3ac703b786:g:UnsAAOSw9eVXUG85&vxp=mtr
There is also a polished one available.
I don't think these are produced by the same person and they are cheaper which may or may not be a good thing.
DANIEL TINDER
Posts: 1.7K, Visits: 144.2K
Frederick E. Johnson (7/5/2016)
Hi All!
The use of oil or sealer can result in leaks, since torquing down the adapter often squeezes the gasket out of place.  A tiny bit of spray trim adhesive to hold the gasket in place on the block while you assemble everything always works for me.
6 VOLTS/POS. GRD. NW INDIANA
DANIEL TINDER
P.S.  Prestige T-Birds used to sell an extra thick gasket that I always use.
Last Active: 1 hour ago
Posts: 4.6K, Visits: 37.8K
Disk brake quiet is a very good sticky spray to hold gaskets in place during tightening. I spray it on both side of the gasket and let it set a minute. Works for me.
Charlie  - does this unit look like the old/other/original one? The older one had good reviews so i would like to know if it works as good s the originals???
