302 y-block
Posted By Jerry's Kars 9 Years Ago
Jerry's Kars
Turbocharged (73 reputation)Turbocharged (73 reputation)Turbocharged (73 reputation)Turbocharged (73 reputation)Turbocharged (73 reputation)Turbocharged (73 reputation)Turbocharged (73 reputation)Turbocharged (73 reputation)Turbocharged (73 reputation)
Posts: 53, Visits: 1.1K
Saw 1963 302 cu in y-block short block. Came from FoMoCo, never ran. Pistons, rods, crank, cam, no heads. What was the application of this engine?
Posts: 6.1K, Visits: 441.8K
A 302, if a Y block, is a Lincoln Y Block, a truck engine.
Jerry's Kars
Thanks Charlie. I got smart and did a net search. Confirmed what you said. Saw the engine at Ford Carlisle. Didn't get the price. Probably not worth  a lot.
LordMrFord
Posts: 687, Visits: 9.3K
I have 303 ci Y-Block, almost 5 litres.
Stock 3.3" stroke with 3.82" bore.
Cylinder walls are thin as paper.
Hyvinkää, FI
Last Active: 11 hours ago
Posts: 4.6K, Visits: 37.8K
I just saw a new 40's style race car at the TROG with the biggest V8 flathead I've ever seen. It turned out to be a 337ci Lincoln. Looked almost as big as the Caddy V12's but with less sparkplugs. Ran very well too had a completely different sound.
http://forums.y-blocksforever.com/uploads/images/55568bbc-c7f1-4fe1-a00c-c70c.jpg
