Visits: 1.2K
So earlier I posted that the speedometer was showing faster then I was actually going about 10 mph faster. So I pulled the gear and found it to be a green one with 21 teeth.. This is for a 59 Fairlane with a Ford O .Started looking for a gear with more teeth finding out it would be easier to look for hens teeth. Any ideas I'm pretty sure I can;t be the first with this issue.As always this forum is a wealth of knowledge.Thanks Dave
Visits: 22.0K
Visits: 1.2K
Thanks that one is for a earlier model
Last Active: 7 hours ago
Posts: 3.6K,
Visits: 497.5K
Found this on ebay - 23 teeth, correct type. make sure the tooth orientation is correct. 371473755411
Visits: 1.2K
Thanks Paul just ordered it will give it a try looks right,
Visits: 14.3K
This may be a dumb question but, does the gear in the trans have to be changed to accommodate the different speedo gear?
Durham Missouri
Visits: 1.2K
Roger PATC didn't have a 23 tooth gear for my 59 Ford O nor could he build a reduction adapter. So I'm trying to fit a gear out of a later model Mustang I'll report back if I win this battle Dave
Visits: 1.2K
Thanks I'm going to try my Mustang gear this weekend if it doesn't work I'll call this co. Dave
