Visits: 472
Coming up short on my water pump to thermostat housing bypass fitting. Does anyone have an extra decent one they will part with? I see Mummert has a snazzy aluminum one available but an old steelie will do as long as it's not corroded badly. Thanks. Barboatbilly1@gmail.com
Bill C
 Drag it home, figure it out.
Visits: 14.3K
Truck or car? There is a difference in the thermo housings. I may have a extra laying around.
Durham Missouri
Visits: 38.0K
I recently saw an article, I think on this forum, about replacing the tube on the thermostat housing. The old one was drilled out and replaced. You could even press in stainless steel tube and end the rust problem. Drill size is important as you want a press in tight fit. Maybe a search will find it?
Posts: 3.6K,
Visits: 497.6K
They make repro - less than 10 dollars. I see them in the CASCO (TBIRDS parts) catalog. This is the fitting that bolts onto the water pump that the hose goes on. Part # 8548. Tbird and sedan are the same.
Visits: 472
Don't need a thermo housing, just the bypass fitting. Shouldn't matter if truck or car right? Looks like new from either Casco or Mummert won't break my budget. Thanks for the Casco lead Paul.
Bill C
Visits: 14.3K
No it doesn't matter car or truck on the tube. I misunderstood. I thought you were looking for the housing.
Durham Missouri
Visits: 190.0K
replace the tube on my truck ,used a piece of 302 oil pickup screen. corect od,add a bit of locktite and presed in to the 292 housing
Visits: 20.6K
I've got one for you. Yours for the shipping. Email sent.
Marc
