Brake switch for 1955 Ford Fairlane
Posted By beachbumrod 9 Years Ago
beachbumrod
Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)
Posts: 2, Visits: 2
Hi I am new to the forum and have been working on the 1955 Ford Fairlane My current issues are I upgraded the master cylinder and the new one doesn't have the port for the old hydraulic switch so I am thinking of installing a mechanical switch on the pedal.I bought a universal  hot rod brake switch that should mount to the pedal. I also need to do some work on the windshield wiper motor as it seem to drag really slowly. I read somewhere to put the tube in trans fluid and let it suck it up into the box to lube it?  and fix the driver side exhaust manifold that has a crack in it. I just had the radiator repaired, replaced the the radiator hoses, changed the cylinder and brake hose on the passenger side. Still need to do the driver side and changed the transmission fluid and install new filter and gasket. Also need to change the oil and install a new filter. On a lighter note I was able to drive it around the neighborhood and it did drive pretty good!
