Visits: 126
I was installing the heads on my 57 312 (Tbird ) and notice that the four outer water ports on the head and block don't have openings on the head gasket .. Is this correct ???
Last Active: 1 hour ago
If there are none at all, then the gasket has been made incorrectly. The gasket should look like this, from ford-y-block.com. You can see that one is large, one is small and the others are totally blocked.
Visits: 126
Thank you , They are the same
Posts: 1.3K,
Visits: 9.2K
Make sure the square corner of the gasket is located front and top on each side of the engine.
-Gary Burnette-
Visits: 126
Gary, will do... thanks again for your help ... I pulled the engine yesterday to get the trans rebuilt... It was rebuilt a few months ago and one of the graphite seals let go
