Visits: 29.3K
Ted, your work is IMPECCABLE!!
Rowen 55CV Woodland, Ca
Visits: 112.0K
Recommendations needed. Who makes the best quality pre-made wire sets? Pertronix says NOT to use solid core wires.
Visits: 4.0K
My Thunderbird didn't have brackets and was a mess, the passenger side wires were zip tied to the trans dipstick. The brackets weren't all that hard to install with those wires and are well worth the effort. If you're not using a really high voltage coil, I would recommend a set of OEM style wires. I got lucky and got a good deal on mine at a silent auction at a multi-club event. The best thing other than being the correct lengths and having extra sleeves for insulation between the brackets is they came with instructions for which wire went where.
Don 55 'Bird, 56 F100 project.
Visits: 113.5K
Greetings to all: About 5 years ago I set out to find the best quality 7mm spark plug wires available and found a company called Magnecor specializing in OEM and race car wires. At that time their part number was 8700 listed under 57 Thunderbird as per my receipt. These are tailor made for the Y-block that indeed fit like a glove with a great stock appearance. The person I spoke to at Magnecor said these wires would be OK with ignition up-grades. Been on my 64 truck 5 years and are just as flexible as the day I bought them. They, however, are not cheap. I'll try to include their web site where there is very good information regarding spark plug wires. Hope this helps, JEFF................... http://www.magnecor.com/magnecor1/main.htm
Visits: 112.0K
FORD DEARBORN (5/8/2016)
Greetings to all: About 5 years ago I set out to find the best quality 7mm spark plug wires available and found a company called Magnecor specializing in OEM and race car wires. At that time their part number was 8700 listed under 57 Thunderbird as per my receipt. These are tailor made for the Y-block that indeed fit like a glove with a great stock appearance. The person I spoke to at Magnecor said these wires would be OK with ignition up-grades. Been on my 64 truck 5 years and are just as flexible as the day I bought them. They, however, are not cheap. I'll try to include their web site where there is very good information regarding spark plug wires. Hope this helps, JEFF................... http://www.magnecor.com/magnecor1/main.htm Thank you, these look like a good quality product. A little pricey but like they say, you get what you pay for..
Visits: 498.3K
I have used Taylor wires on a number of cars and never had a problem with them. Currently on four cars including 2 312's. Not sure if pre-made for a Y Block, always bought the universal kit so I can make whatever mods I want to.
QUOTE" Recommendations needed. Who makes the best quality pre-made wire sets? Pertronix says NOT to use solid core wires.
Visits: 283
Those pictures help a lot Ted, Thanks. I definitely have to get my wires routed back the way they are supposed to be.
