1955 Ford Crown Victoria - Stock Air Cleaner Housing question
Posted By raybaker1 9 Years Ago
raybaker1
Supercharged (181 reputation)Supercharged (181 reputation)Supercharged (181 reputation)Supercharged (181 reputation)Supercharged (181 reputation)Supercharged (181 reputation)Supercharged (181 reputation)Supercharged (181 reputation)Supercharged (181 reputation)
Last Active: 7 Months Ago
Posts: 53, Visits: 234
  Stock Air Cleaner Canister/Housing question - I have a 1955 Ford Crown Victoria and want to modify the stock oil bath canister to accommodate a modern day dry air filter in the canister.
   1. Here are some of my concerns.
a. Getting enough air flow across the dry filter.  Should I drill holes up through the bottom of the canister to get the air flow?
b.  Well I have enough space to use this stock canister and still close my hood?  I have a 1957 intake and a 390ci Holley carb. on the engine now.  I am afraid to put the stock air filter housing/canister on the carb now and try to close the hood.  Thinking that the hood and canister will hit and I will damage my hood.
NOTE - I  am sure that somebody has mod-ed a stock air canister to accommodate a modern day dry air filter.  If you have please give me a heads up on what you did.  If possible send pictures.
Thanks,
Ray
Talkwrench
Posts: 898, Visits: 23.2K
Are you talking about the 55 two barrel one?  Real pain in the butt to do The 56 type is easier ..
Lou
Last Active: 1 hour ago
Posts: 560, Visits: 8.3K
There is a problem with you plan to convert to a paper filter. It's not an improvement, oil bath air cleaners are the best designed air filter ever made for  a vehicle they are 98% efferent where a paper filter is only about 80% efferent. That is why oil baths filter are used on large trucks and in off road racing.
While I don’t have any experience in converting a 1955 oil bath air cleaner so it’s a dry paper design, I have done that modification to a 1956 four barrel air cleaner.  The ’56 air cleaner I worked with had rust holes at the bottom of the oil reservoir so it was a good candidate for this.  I basically cut the series of baffles from the lid and then installed two Wix #42061 air cleaner elements stacked within the housing which clamped down with the original lid.  I did cut some ¾” holes in the bottom of the housing for additional air flow to the paper elements.  Runs and looks good.  Here are some pics.
http://forums.y-blocksforever.com/uploads/images/8ad8ae43-d4a7-4df9-a2bd-fad5.jpg http://forums.y-blocksforever.com/uploads/images/03bd426d-4175-4de4-b047-d86b.jpg
http://forums.y-blocksforever.com/uploads/images/f5fcb65f-7803-424b-9c1c-85e3.jpg http://forums.y-blocksforever.com/uploads/images/98a04c97-1f38-4707-90d2-defd.jpg
http://forums.y-blocksforever.com/uploads/images/11052fa0-4b1c-4be6-97a9-44cc.jpg http://forums.y-blocksforever.com/uploads/images/2b8eb1d1-d29f-413d-a46f-6ca8.jpg
carl
Posts: 1.2K, Visits: 20.6K
Ted The air cleaner that you modified is actually a 55 and not a 56.The 55 has a horizontal bar in the air inlet like yours and the 56 has either a vertical bar or is open without a bar.Also the 55 has a concave section on the bottom for heater control valve and the 56 is straight across.The 56 also has a concave section just above the choke housing for clearance which the 55 didn't need.Great instruction though and I think I will do my 56 now.Do you think that there is a increase in air flow with the dry filter verses the oil bath?
 Carl
