By raybaker1 - 9 Years Ago
Stock Air Cleaner Canister/Housing question - I have a 1955 Ford Crown Victoria and want to modify the stock oil bath canister to accommodate a modern day dry air filter in the canister. 1. Here are some of my concerns. a. Getting enough air flow across the dry filter. Should I drill holes up through the bottom of the canister to get the air flow?
b. Well I have enough space to use this stock canister and still close my hood? I have a 1957 intake and a 390ci Holley carb. on the engine now. I am afraid to put the stock air filter housing/canister on the carb now and try to close the hood. Thinking that the hood and canister will hit and I will damage my hood.
NOTE - I am sure that somebody has mod-ed a stock air canister to accommodate a modern day dry air filter. If you have please give me a heads up on what you did. If possible send pictures.
Thanks,
Ray
By Talkwrench - 9 Years Ago
Are you talking about the 55 two barrel one? Real pain in the butt to do The 56 type is easier ..
By Lou - 9 Years Ago
There is a problem with you plan to convert to a paper filter. It's not an improvement, oil bath air cleaners are the best designed air filter ever made for a vehicle they are 98% efferent where a paper filter is only about 80% efferent. That is why oil baths filter are used on large trucks and in off road racing.
By Ted - 9 Years Ago
While I don’t have any experience in converting a 1955 oil bath air cleaner so it’s a dry paper design, I have done that modification to a 1956 four barrel air cleaner. The ’56 air cleaner I worked with had rust holes at the bottom of the oil reservoir so it was a good candidate for this. I basically cut the series of baffles from the lid and then installed two Wix #42061 air cleaner elements stacked within the housing which clamped down with the original lid. I did cut some ¾” holes in the bottom of the housing for additional air flow to the paper elements. Runs and looks good. Here are some pics.
By carl - 9 Years Ago
Ted The air cleaner that you modified is actually a 55 and not a 56.The 55 has a horizontal bar in the air inlet like yours and the 56 has either a vertical bar or is open without a bar.Also the 55 has a concave section on the bottom for heater control valve and the 56 is straight across.The 56 also has a concave section just above the choke housing for clearance which the 55 didn't need.Great instruction though and I think I will do my 56 now.Do you think that there is a increase in air flow with the dry filter verses the oil bath? Carl
