312 with supercharger for sale on Ebay
Posted By MoonShadow 10 Years Ago
Posted 10 Years Ago
Last Active: 5 hours ago
Posts: 4.6K, Visits: 39.4K
This Y and McCulloch setup is in Arizona. Don't know anything about it but wanted to make sure the Y'guys saw it. Chuck
I tried to cut and paste the address but couldn't paste into this window. ?
EBAY
http://www.ebay.com/itm/182055047200?euid=dbfef3c16be54a758e16d2e7aea80c46&cp=1&exe=13926&ext=35633&sojTags=exe=exe,ext=ext
Rono
Posted 10 Years Ago
Posts: 1.3K, Visits: 80.0K
Pretty interesting set-up. Lots of good parts; Ram's horns, dual quad, power steering and all the correct brackets and pulleys not to mention the VS-57 itself. You could probably part it all out for 4K.
Rono
Daniel Jessup
Posted 10 Years Ago
Posts: 2.0K, Visits: 131.2K
What a bunch of eye candy!!!
I would be concerned though about the "dust" sitting on that setup. It almost looks like sandblasting dust. Makes you wonder if the PO had the engine sitting the truck/vehicle while he was sandblasting the frame or sheet metal, etc. The "0" transaction and feedback of the seller would also keep me pretty wary.
If I only we could check it out in person!
Daniel Jessup
Red Lion, Pennsylvania
mgcookwv
Posted 10 Years Ago
Supercharged (410 reputation)Supercharged (410 reputation)Supercharged (410 reputation)Supercharged (410 reputation)Supercharged (410 reputation)Supercharged (410 reputation)Supercharged (410 reputation)Supercharged (410 reputation)Supercharged (410 reputation)
Posts: 150, Visits: 283
is it safe to put a supercharger on a 60 year old engine, they weren't geared for high rpm's?
Posted 10 Years Ago
It would be a good idea to freshen it up, but there are plenty of blown Y blocks around, including the red car in the photo here.
Posted 10 Years Ago
Posts: 1.9K, Visits: 195.0K
I put a Paxton on the stock rebuilt 292 in my bird some years ago. Even at 5lbs boost @5000 rpm, you could feel it come in at about 3000 rpm. No problems in street driving. Now, you want to lay the wood to it for 1/4 mile at a time like Frank does, it's going to be a different deal. But low boost, good fuel, don't let it detonate, you'll be fine. Posted heads came about from race usage, not mild street duty.
When I built the 320 stroker, with a measured 9:1 compression ratio, it was premium, octane booster, ignition retard on the MSD. But it was a street motor, and I was willing to give up some top end for the low end response. Posted, ported heads. That one would have been a pretty good race motor with less compression and more boost.
