1957 BIRD QUESTION
Posted By Lord Gaga 9 Years Ago
Lord Gaga
Posts: 464, Visits: 183.3K
Did the 1957 "C" Birds (292) come from the factory with a four barrel carb?
http://forums.y-blocksforever.com/uploads/images/1cb328e0-a857-44f4-8050-2b55.jpg
"FREE SAMPLE"
'57 'C' 'Birds were equipped with a two barrel carburetor and a 3 speed only manual transmission.
Hope this helps.   Smile
skygazer
Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)
Posts: 112, Visits: 1.5K
Yup.  Here's an example of a C-bird restoration blog.
Lou
Last Active: 6 days ago
Posts: 563, Visits: 8.4K
In the 1980s I had a low mileage "C" bird with overdrive. I've never seen one but several years ago a "C" was advertised locally with automatic.
slumlord444
Posts: 1.2K, Visits: 137.8K
Not sure about transmission options but definitely 2 barrel carb. I would think that any transmission would have been available though.
For 1957 as far as I'm aware, all vin "C" letter 292 cu. inch Ford cars, came with the then new design 2 Bbl carbs. Only  312s got a 4 bbl.
Lord Gaga
Thanks guys. I wasn't sure if the intake on my engine had been changed in the past or not...it was. That Bird in the blog is nice except for the 312 valve cover decals (!?) and the early exh. manifolds.
"FREE SAMPLE"
'57 'C' code Birds from the factory were equipped with only the 292 engine and that only came with a two barrel carburetor and a medium duty 3 speed only manual transmission.  In '57, the 'C' code '57 'Bird was the least expensive base model 'Bird you could buy.
In '57, to get the FordoMatic or the heavy duty T-85 with overdrive in a 'Bird you had to step-up to a 'D', 'E', or 'F' code which came with the 312 engine.
Like some of you, I've seen numerous '57 'C' 'Birds outfitted with 292 engines and four barrel carburetors, 'C' 'Birds with 312 engines, and 'C' 'Birds with FordoMatic transmissions.  None of these were originally offered or released from FoMoCo equipped this way.  Not all 'Bird enthusiasts are purists!   Hehe
Sounds healthy to me!   Smile
