Modern 2bl carb
Posted By Rowen 9 Years Ago
Rowen
Posts: 435, Visits: 29.3K
Is there a modern 2bl carb that will fit my stock 55CV with manual choke? Thanks
Rowen
Rowen
55CV
Woodland, Ca
30 coupe
Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)
Posts: 130, Visits: 3.4K
you can get an adapter here.   http://www.speedwaymotors.com/?gclid=CKG_stbImMsCFUZrfgodXBUK0Q
Edelbrock make old style 2 barrels.  You'd have to check with them about modernization.
Stromberg also still make carbs and they do advertise improved fuel circuits and ported vacuum.  They also have a Big 97 (250cfm).
If you can find them, Demon made some modern 3-bolt carbs.
Are you still using the Loadmatic distributor? I'm not sure if "modern" carbs will work if you do. Putting a 57+ dist can be used with a 6 volt stock or a 6 volt Pertronics if you are still have 6 volts. I'm sure other here do know and will chime in..... Good Luck.
