By Rowen - 9 Years Ago
Is there a modern 2bl carb that will fit my stock 55CV with manual choke? Thanks Rowen
By 30 coupe - 9 Years Ago
you can get an adapter here. http://www.speedwaymotors.com/?gclid=CKG_stbImMsCFUZrfgodXBUK0Q
Edelbrock make old style 2 barrels. You'd have to check with them about modernization.
Stromberg also still make carbs and they do advertise improved fuel circuits and ported vacuum. They also have a Big 97 (250cfm).
If you can find them, Demon made some modern 3-bolt carbs.
Are you still using the Loadmatic distributor? I'm not sure if "modern" carbs will work if you do. Putting a 57+ dist can be used with a 6 volt stock or a 6 volt Pertronics if you are still have 6 volts. I'm sure other here do know and will chime in..... Good Luck.
