Automatic Transmissions for a Y Block
Posted By Kahuna 9 Years Ago
Kahuna
Posts: 471, Visits: 2.4K
I'd like to know what AUTOMATIC transmissions are out there that have the Y Block bolt pattern?
Other than the Fordomatic I now have.
FMX? Mercomatic? Anything else
Also, any that are Aluminum cased?
Jim
Last Active: 9 hours ago
Posts: 4.6K, Visits: 38.5K
There is an aluminum Ford-O-Matic but its a true 2 speed no shifting down to 1st. If you want  better setup there are a lot of adapters out there. John Mummert http://www.ford-y-block.com he has adapters for C-4 swaps. There are also adapters for AOD's if you fancy an overdrive. Chuck
Posts: 1.9K, Visits: 194.9K
More choices than you wanted
http://www.transmissionadapters.com/ford_y_block.htm
Kahuna
Hey Moon
What years was the 2 speed used?
Jim
I'm not exactly sure but it was the later years around 1960 on I believe.
carl
Posts: 1.2K, Visits: 20.6K
MoonShadow (1/15/2016)
  I had a 59 Edsel 292 that had the 2 speed trans,not sure if that was the 1st year for it though   Carl
Posts: 3.7K, Visits: 497.8K
1959 was the first year.  I don't know when they stopped them, but there were two speed C-4's in 64.  Around 64 was the first 3 speeds I think
Kahuna
Last question for the night:
Moon
I really like the scoop on your 56. What's it from?
Very cool
Jim
The carb bonnet is an old McCullouch product. Came with some blower parts.
Kahuna
The hood scoop?
Jim
