Automatic Transmissions for a Y Block
http://forums.y-blocksforever.com/Topic119674.aspx
By Kahuna - 9 Years Ago
I'd like to know what AUTOMATIC transmissions are out there that have the Y Block bolt pattern?
Other than the Fordomatic I now have.
FMX? Mercomatic? Anything else
Also, any that are Aluminum cased?
Jim
By MoonShadow - 9 Years Ago
There is an aluminum Ford-O-Matic but its a true 2 speed no shifting down to 1st. If you want  better setup there are a lot of adapters out there. John Mummert http://www.ford-y-block.com he has adapters for C-4 swaps. There are also adapters for AOD's if you fancy an overdrive. Chuck
By miker - 9 Years Ago
More choices than you wanted
http://www.transmissionadapters.com/ford_y_block.htm
Hey Moon
What years was the 2 speed used?
Jim
I'm not exactly sure but it was the later years around 1960 on I believe.
By carl - 9 Years Ago
MoonShadow (1/15/2016)
  I had a 59 Edsel 292 that had the 2 speed trans,not sure if that was the 1st year for it though   Carl
By paul2748 - 9 Years Ago
1959 was the first year.  I don't know when they stopped them, but there were two speed C-4's in 64.  Around 64 was the first 3 speeds I think
Last question for the night:
Moon
I really like the scoop on your 56. What's it from?
Very cool
Jim
The carb bonnet is an old McCullouch product. Came with some blower parts.
The hood scoop?
Jim
A bit confusing, I don't have a hood scoop on the Vicky. The hood has been modified with the mascot removed and louvered. I used the hood latch section from a 55 Ford and the 55 grill surround to give the tube grill a more finished look.
 Chuckhttp://forums.y-blocksforever.com/uploads/images/ec745874-8bdb-41c8-817a-23e3.jpg
By Small block - 9 Years Ago
Kahuna (1/14/2016)
Jim
There is a stock ford  bell   that was used in 1964 ford pickups to bolt 292 to a  C-4
3 speed they are rare but I seen  one at a swap meet last summer  The part number is C4AP-7976-c!
Thanks Small Block
Also, Moon I was talking about the hood scoop in the avatar.
This could go on forever
Regards
Jim
No problem, are you talking about the engine, under hood picture or the car profile. Chuck
Ha Ha Ha
It appears to me that in the pic in the avatar that there is a hood scoop installed? Maybe it's just the lighting and again I am confused.
I apologize. I am talking about the car pictured (not avatar) next to the engine picture that appears
Jim
I thought it might be that picture. It is a reflection.
http://forums.y-blocksforever.com/uploads/images/023565eb-915b-437d-bebb-2f2d.jpg
Thanks for the clairification. My eyes are getting old.
Very nice car
Jim
No problem, everything I've got is getting old.
By Cliff - 9 Years Ago
Hi, has anybody else seen a factory bell housing to put a c4 behind a Y block?
Cliff (1/20/2016)
Do a search  for  Transmission  Supply C4-C5 Bell application and you will find this  bell listed under 292 and also for 272!
It was  available at one time  there is no way of being sure  of finding one  now!
Cliff (1/20/2016)
C1 AP 7976 A-1  & C1AP 7976 A-2 are aluminum y block bellhousings that ford o matic,cruise o matic and FMX will bolt up to.  Carl
By PF Arcand - 9 Years Ago
Just a note for anyone that might have Y-blk automatic bell housings around that are not needed. Bristol Services in Costa Mesa CA is advertising for them & Flex plates also. contact; garycroan@gmail.com or 949-722-1122... Not sure why he hasn't advertised here? Was advised of the site some time ago..
