Visits: 20.6K
There are two styles of factory duals, 55-56 and '57-up(flat tops). Both types dump to the rear of the engine but the '57s flow a little better. Both are much better than the single exhaust with crossover pipe. One solution is to eliminate the crossover, cap your passenger side manifold at the front and add a rear dump manifold for the drivers side. If you want to go that way, I have a single driver's side rear dump for the 55-56 that I would sell. If you're interested, email me me at roadqwesty914@comcast.net. Good luck with your 292, you're going to love it.
Marc
Visits: 59
those are for sure the ones i'd need?
Visits: 59
Stuey, those ebay ones you posted are for sure the ones i'd need? i'd rather replace both manifolds and have a matching set than just the drivers side and cap off the front of the passenger side.
Visits: 22.0K
If they're flat tops you're golden.
Visits: 3.4K
Rowen, does your car have an automatic, or stick. just wondering how your cam will work with an automatic. If you have an automatic, are you changing to a different ( high stall ) torque converter? Just trying to get a feel for how that cam may work with an automatic trans. .
Visits: 29.3K
30coup, at the moment the car is stock. 272 2bbl, fordo, 6v +ground. I will be retiring in about 1 1/2 yrs and that's when I will be hotrodin her. She will will have a T5. No, you are correct, the fordo will not work with the engine goin in her. I am and will be on a pretty strict budget for the build so I am collecting parts and pieces as I can find and afford them. Rowen
Rowen 55CV Woodland, Ca
Visits: 3.4K
Thanks, I was not sure of the spec's on your cam. I am also gathering parts for my 312 build, and have not made a cam selection.
Visits: 29.3K
30coup, my cam selection was sort of made for me. It was in the engine when I purchased it. It was a project build that got put on a back burner. It is a 312 sleeved down to a,,,,3.75 (292?) bore. It is 304 c.i. Got a GREAT deal on it!! All new internals, never been run. As for the cam, I may change it out later, but for now, it's staying in. Rowen
Visits: 37.8K
Once you decide what you are going to do to your engine there are several members here that can recommend a cam. John Mummert has a lot of information and choices on his web page at: http://www.ford-y-block.com/
Visits: 59
Thank you all for the advice. The guy I bought my car from hooked me up with a pair of manifolds after I told him what I was wanting to do and that I was looking at a set on ebay. He just happened to have a set! I'll try and see about posting pics soon.
