56-57 3 tooth steering sector
Posted By 62bigwindow 9 Years Ago
Last Active: 9 days ago
Thanks Bill! Sorry to hear that. Another one stop Source of Parts for Vintage Vehicles gone. I was just going by their Website which is still active and no indication they are closing up. Too bad. One more suggestion for sourcing the Sector Shaft-try Dennis Carpenter. He has or did have a very large # of NOS Parts for Fords. You used to be able to access the Inventory directly off the Website using original Ford Part #'s but I don't see that Link on His new Website. You may have to call them and give them that Part #.
62bigwindow
Posts: 884, Visits: 14.3K
Thanks for all the help. After several emails and even more phone calls I came up empty handed. The rebuilder is a reputable shop and he said that it turned out good with the used sector. I should have it back later this week so I'll keep everyone up to date.
Durham Missouri
30 coupe
Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)
Posts: 130, Visits: 3.4K
Don't know if it would help, but you could try Kanter Auto.         https://www.kanter.com/
Dobie
Posts: 476, Visits: 22.0K
Also try Green Sales Co. They are in Cinci, not MI as I mistakenly said in another post. You can input the ford part number on their website.
Green Sales Co. don't have one.
I ran into the same problem in western Canada. Could not find any shop or supplier that could supply needed parts to rebuild a (very bad) 57 car steering box.
Ended up converting to a 1958, ( box only) which has the later recirculating ball mechanism. However, in the case of a 1957 to 58 conversion, definately best to use the complete 1958 column assembly, because the entire horn & turn signal setup is revised starting in '58. Otherwise, sorting that out is another whole story...
