Visits: 2.4K
Thinking of Grumps suggestion, regarding buying a whole car for parts How would I find out what cars (Ford, Merc, Lincoln). between 1988 and 1993, would have the AOD? Any thoughts or suggestions appreciated. Jim
Last Active: 8 hours ago
Visits: 38.5K
It was pretty well the standard then for Mustangs with automatics. I found mine on EBAY. I would look there, on cragislist and then the local wrecking yards. Do a search for AOD on google and see if you can find a listing of what the came in. The later AOD's were AODE's which means they are computer controlled. You would need the computer setup on your car. For that reason only a few have opted for them. If you don't mind the electronics I guess that may be a way to go. Chuck
Posts: 1.9K,
Visits: 194.9K
Jim, I've never used these guys, so I can't recommend them. I came across them some time ago, looking at the AOD's for a project that went away. You've got to dig a bit, but there's a lot of info buried in the technical and FAQ sections. Might just add to the general knowledge. http://www.becontrols.com/index.shtml
Visits: 2.4K
Thanks, Miker
