Randon Question
Posted By daustin 11 Years Ago
daustin
Turbocharged (67 reputation)Turbocharged (67 reputation)Turbocharged (67 reputation)Turbocharged (67 reputation)Turbocharged (67 reputation)Turbocharged (67 reputation)Turbocharged (67 reputation)Turbocharged (67 reputation)Turbocharged (67 reputation)
Posts: 15, Visits: 579
Does anyone know where I can find this part circled in yellow in the picture?  Can't find it anywhere and don't even know what to call it other than "plate".
Also, does anyone know what bolts/screws hold the glove box lock into the dash?
On another note, I ordered my steering column and associated install parts, lokar shifter, radiator, and 21 circuit wiring harness. My build is gaining momentum!
Thanks!  Dave
http://forums.y-blocksforever.com/uploads/images/d0eef1a2-54e0-4e85-bb9c-10f4.jpg
Posts: 3.7K, Visits: 498.2K
I was under the impression that that piece was spot welded to the main dash.  That holds the light - right?
daustin
paul2748 (12/28/2015)
Definitely not spot welded. It has it's own part number but cant locate the part by the part number.  I do have the bigger one that houses the ignition switch, lights, etc.... This one secures the lighter and choke.  I don't need either but I don't want the holes in my dash.
carl
Last Active: 6 days ago
Posts: 1.2K, Visits: 20.7K
daustin (12/28/2015)
I have a couple 55 dashes,I will check and see if that part is with them  Carl
Oldmics
Posts: 710, Visits: 78.1K
Its listed in the 1956 Ford chassis book as - ready for this - Its called a plate!
Plate -  (Insturment Cluster Controls Mounting)
Part# B5A 11573-A  for the right side and B5A 11575-A for the left side
Oldmics
carl
Thanks!  Dave
I have the part you need Carl
daustin
carl (12/28/2015)
Thanks!  Dave
How much would you like for it?
daustin
Oldmics (12/28/2015)
Oldmics
Yeah, they got real descriptive with that one!  Called the same in my books. Haha
