New Aftermarket Crankshafts
Posted By MontyRay56 11 Years Ago
aussiebill
Posted 10 Years Ago
Posts: 1.8K, Visits: 11.4K
Ted (12/6/2015)
Small block (12/6/2015)
It would be nice to have a set of bearing spacers like was used in the 400 SBC when they used to install the 350 crank in the 400 block! Then the 292 crank would fit both small and large main size.
While the bearing spacer sounds like a viable option, those main bearing spacers used on the 400 SBC blocks with a 350 crankshaft were problematic from both a fit and heat transfer aspect.  As a result of that, there was a special ‘thick’ bearing that became available for that application but those were exorbitantly expensive compared to a standard thickness bearing.  If there was enough demand, a special thick bearing could be manufactured to put a 292 mained crankshaft in a 312 block
Ted and adding to that, as you know, good 312 blocks are not allways available and lessens these ideas. i think remaking the small main journal 3.44 stroke is commonsense approach.
 Down Under, Australia
John Mummert
Posted 10 Years Ago
Posts: 919, Visits: 7.5K
I don't know when or if the Scat will be available so in the mean time I am having new rods made that are 312 length and width but take a 2" bearing.
This will allow you to take your 272-292 crankshaft to a local crank grinder and have it offset ground to 312 stroke. You will then be able to use off the shelf 312 pistons and make a 312 out of a 292 at an affordable price.
We expect delivery in late June. Rods are 5140 I-Beam with doweled cap and cap screw bolts. The standard rods come with 8740 cap screws and ARP2000 rod bolts will be available.
Although similar to the 318 stroker kit we have offered in the past the new rods will not require widening the rod journal. Not many crank grinders would widen the rod journals enough to fit aftermarket 2.0" journal rods so the process will be much simpler.
Although off the shelf pistons would not work the new rods could be used with a 312 crankshaft offset ground to 3.60-3.61" stroke.
http://ford-y-block.com
slumlord444
Posted 10 Years Ago
Last Active: 5 Months Ago
Posts: 1.2K, Visits: 137.8K
So I can take a forged 292 truck crank and make a 312 crank out of it?
LordMrFord
Posted 10 Years Ago
Posts: 687, Visits: 9.3K
With 292 mains and smaller rod bearing size, yes.
I think that cast crank can take all abuse what naturally aspired Y can offer without going really high rpm's.
Bad balancing jobs are different story.
Hyvinkää, FI
Posted 10 Years Ago
Posts: 7.6K, Visits: 206.1K
I did talk with SCAT earlier this week and when I asked about the production of the upcoming Y crankshaft, they said it will not be available now until this time next year.
LordMrFord
Posted 10 Years Ago
Ted (5/8/2016)
I thought chinese were faster to get tin copies from stuff but maybe I was wrong.
Hyvinkää, FI
John Mummert
Posted 10 Years Ago
They are. The problem is simple. There is no forging die in China that has enough material to make the Y-Block snout.
I've looked into having cranks made and the answer is always the same. Went through a couple of connections, Same answer.
So, there would have to be a new die, modify an existing die or weld material on the forging to make the snout long enough.
I have cast 4 samples of the crankshaft I was trying to make here but finding someone to machine it is another story. Best price so far $1100.00
for machining only.
For now, offset grind or wait. Or go to a billet crankshaft.
John Mummert
Posted 10 Years Ago
slumlord444 (5/8/2016)
Ron, that is the idea. Either steel or cast crank offset ground to 3.44" stroke.
Offset grinding at standard width should cost around $150-200
Posted 10 Years Ago
Seems like a company such as Scat, who is in the business of making cranks would either make it happen or not.  Pushing the introduction back another year is pretty well a good indication that they're not going to do it.
aussiebill
Posted 10 Years Ago
John, sounds like you,ve come up with an achievable alternative to 312 with that new rod! i like the idea, thank you.
