manual choke to a electric choke?
Posted By mgcookwv 10 Years Ago
mgcookwv
Posted 10 Years Ago
Supercharged (410 reputation)Supercharged (410 reputation)Supercharged (410 reputation)Supercharged (410 reputation)Supercharged (410 reputation)Supercharged (410 reputation)Supercharged (410 reputation)Supercharged (410 reputation)Supercharged (410 reputation)
Posts: 150, Visits: 280
Is it a hassle to convert over to an electric choke, I'm having trouble getting my cable exact tension and  getting it to idle when it starts and it dies if you don't keep your foot on the gas. I've had trouble with this ever since I bought the car and need to fix it. The previous owner had a concoction on the cable coming through the dash to tighten the unit down on the back side of the dash but that's no longer an option so I figured I'd go with electriv if feasible.
56vikki
Posted 10 Years Ago
Turbocharged (63 reputation)Turbocharged (63 reputation)Turbocharged (63 reputation)Turbocharged (63 reputation)Turbocharged (63 reputation)Turbocharged (63 reputation)Turbocharged (63 reputation)Turbocharged (63 reputation)Turbocharged (63 reputation)
Posts: 24, Visits: 324
I put a Holley 600 cfm electric choke carb on my 62 ford and ditched the autolite 4100 manual choke one.It starts and idles fine .This was 7  years ago.
Posted 10 Years Ago
Posts: 3.6K, Visits: 497.5K
What carb - 4000, 4100, 4150?  2 or 4bbl?
If it's a 57 and later Holley, then Holley should be able to supply the parts.  As far as a 4100, I don't where you can get parts for an electric choke.
If a 4000, there is a company that has a conversion kit    https://www.carburetor-parts.com
Half-dude
Posted 10 Years Ago
Supercharged (567 reputation)Supercharged (567 reputation)Supercharged (567 reputation)Supercharged (567 reputation)Supercharged (567 reputation)Supercharged (567 reputation)Supercharged (567 reputation)Supercharged (567 reputation)Supercharged (567 reputation)
Posts: 215, Visits: 11.2K
I'm having hella a lot of trouble with my automatic spring choke on my 4000. I dunno if changing the spring would be enough to fix it.
mgcookwv
Posted 10 Years Ago
It's a 55 Fairlane 272 4000 tpot carb!!
2721955meteor
Posted 10 Years Ago
Posts: 927, Visits: 190.0K
my 1957rnchero with holley 4v ,electric choke works great
Posted 10 Years Ago
Last Active: 5 days ago
Posts: 1.8K, Visits: 190.6K
Since you really didn't get an answer.
I've never had to use a locking choke cable on any kind of carb. There's always been enough friction to hold the choke closed. That said, you still have to adjust the fast idle steps separate (or coordinated with) the choke itself. That won't change with an electric unit. On some carbs, this requires bending the linkage from the choke to the choke betterfly to get it in sync with the fast idle adjustments. On a 60 year old carb, who knows what's been done.
You might go over to the Ford Barn and look up scicala. He's a well regarded carb guy, but is rarely on here.
Kahuna
Posted 10 Years Ago
Posts: 471, Visits: 2.4K
I converted one of my Holley 4000's to electric. It works great
Here you go:
https://www.youtube.com/watch?v=rkJkCWhip4c
