Load-o-matic and teapot carb questions
Posted By mustangdude86 11 Years Ago
mustangdude86
Posted 10 Years Ago
Normally aspirated (36 reputation)Normally aspirated (36 reputation)Normally aspirated (36 reputation)Normally aspirated (36 reputation)Normally aspirated (36 reputation)Normally aspirated (36 reputation)Normally aspirated (36 reputation)Normally aspirated (36 reputation)Normally aspirated (36 reputation)
Posts: 15, Visits: 41
Thanks for the replies and info.
As far as the distributor goes, is it worth adding that the car has been converted to 12 volt? Not sure if that effects anything.
Posted 10 Years Ago
Last Active: 4 hours ago
Posts: 3.8K, Visits: 33.1K
Doesn't make a difference unless you are using Pertronix.
mustangdude86
Posted 10 Years Ago
I'm not sure I'm entirely familiar with that? Is that 12v vs 6v coil?
Posted 10 Years Ago
It does make a difference.
With 12v points ignition, a ballast resistor is needed.  With 6v, no resistor is needed.
Electronic ignition conversions are too varied to generalize.  Simply follow the instructions  for the 12v conversion you choose.
Posted 10 Years Ago
You are right Charlie. He will also need the 12 Volt Solenoid and wire a bypass to Coil for Starting. Otherwise the Ballast resistor will fry the first time it is started..
mustangdude86
Posted 10 Years Ago
See here's the thing, my dad had this thing converted to 12V almost 2 decades ago. So I haven't a clue as to what it's current state is.
My dad does remember the guy telling him something about it using some sort of tractor coil that uses 6V to start and 12V running. I could have that backwards, but it's something like that.
My plan was to go with the conversion that the guy at FBO systems does http://www.4secondsflat.com/Ford%20Y-Block%20Distributors.htm
My understanding is that they supply to coil needed after converting my distributor with the new parts. Keeping the original shaft so it plugs back in the original location and works fine.
mustangdude86
Posted 10 Years Ago
I've been hunting to find instructions on how to pull out my distributor to send it in for conversion with no luck. Any hints, ideas, recommendations on how to do this, and then reinstall it properly?
