Weighed my '57 Custom Sedan Today 3940lbs
Posted By suede57ford 11 Years Ago
I suspect that a 429 or  460 engine in a T.Bird would be great for power, but not so for weight distribution, as I believe they weigh in at about 700+ lbs.!
tbirddragracer
Supercharged (132 reputation)Supercharged (132 reputation)Supercharged (132 reputation)Supercharged (132 reputation)Supercharged (132 reputation)Supercharged (132 reputation)Supercharged (132 reputation)Supercharged (132 reputation)Supercharged (132 reputation)
Posts: 56, Visits: 95.8K
Paul,
 I think the difference in weight between the y-block and the 460
is approximately 100 to 110 lbs. depending on acessories.
Not that much. My car has a Kugel IFS front suspension system,
 and handles great.
Ernie Phillips
suede57ford
Posts: 216, Visits: 106.5K
One advantage to the T-Bird on weight distribution is the engine is set back nearly behind the front wheels.   If you look at the upper control arms of a 55-57 T-Bird you will see they are ahead of the motor, so the engines weight is not all on the front wheels.  The rear wheels are just right behind the seat.  The setback engine and short wheel base is probably an advantage for the T-Bird.   I would guess that the 460/c6 with headers and aluminum intake is not that much more than a Y-Block with a factory supercharger set-up and either a t-85 w/cast bell housing or even heavier a Fordomatic.
My T-Bird has a Cavalier rack and pinion on the front.    It has some bump-steer issues, that I need to work out. I haven't spent much time on it since I'm going back to the factory manual steering when I put the Y-Block back in.
I originally bought my T-Bird to do an F-clone and race it a the Y-Block Shoot-Outs.   I figured it would make a nice combo with two black VR57 powered street/strip cars.T
Pat Fleischman
ian57tbird
Posts: 502, Visits: 21.7K
The cast iron trans really kills the weight of the original cars. Even with the 460 yours still comes out lighter than my TBird.
