Visits: 1.1K
So jepito You are running waste fire, how has that been? And what cam and performance are you getting with the set up? Looks awesome by the way!
Your probably right Charlie, however I know you can see the valve stems with the manifold off.
Visits: 541
The ignition is triggered off the rear of the crank and works great. It has provisions for a MAP sensor to use for vaccum advance, but have not hooked it up yet.
The throttle bodies are modified hilborn. It is mechanical fuel injection with defector tip nozzles. I was hoping to run it in the engine masters challenge but am on the wait list. It's 333ci and made 445hp @ 5800 on pump gas with some room to improve with better air horns and headers.
Visits: 9.3K
Open 8 stack might hurt the mid power for emc but who remember the more powerful scrubs if you got really nice injected Y agains them.
 Hyvinkää, FI
Visits: 541
Individual runners work well for mid range. Dyno pulls were 4-6k and basically flat torque over 400lbft
Visits: 541
Visits: 14.0K
Nice
Visits: 1.1K
Curious of others that have had succes running EFI on the Yblock I'm personally running a Holley Terminator on a mummert low rise with a 1/2" open spacer.
Visits: 21.8K
I'm running twin GM throttle bodies on an "e" manifold on my T'bird and I really like it,woke up the low end nicely and doesn't load up like the hollers did. I have 273's n the rear and an old super T10 special wide with the 264 first gear and the bird will run 80 mph all day long. MIKE
Visits: 29.3K
Hey mike, I too have a "E" code intake with two original Re-built holleys on board. What throttle bodies did you use? They work well together? Did you need adapters? How is the throttle response? Power? Thanks in advance mike, Rowen
Rowen 55CV Woodland, Ca
