M335
Posted By bobo1 11 Years Ago
bobo1
Supercharged (100 reputation)Supercharged (100 reputation)Supercharged (100 reputation)Supercharged (100 reputation)Supercharged (100 reputation)Supercharged (100 reputation)Supercharged (100 reputation)Supercharged (100 reputation)Supercharged (100 reputation)
Posts: 42, Visits: 262
Hello I just have to buy for my Lincoln 368ci a M335 Manifold http://forums.y-blocksforever.com/uploads/images/3a130c78-5f6f-4adf-8700-a336.png
I would like to know what are the diference on my Lincoln and Mercury 335
yalincoln
Supercharged (573 reputation)Supercharged (573 reputation)Supercharged (573 reputation)Supercharged (573 reputation)Supercharged (573 reputation)Supercharged (573 reputation)Supercharged (573 reputation)Supercharged (573 reputation)Supercharged (573 reputation)
Posts: 378, Visits: 4.8K
they are the same engine except for the intake and valve comers. the 335 setup was for the 57 merc. for nascar.
Oldmics
Posts: 710, Visits: 78.1K
Lincoln did not use the M 335 setup. It was a 1957 Mercury only option. It will fit on the Lincoln since they both use the 368 engine.
The setup that you show only has the intake manifold as a correct part from the M 335 setup. The M 335 used Holley carbs.
I have the correct reproduction air cleaners for the M 335 setup that go ontop of the correct Holly carbs if interested.
Oldmics
Oldmics
http://forums.y-blocksforever.com/uploads/images/ca34a82b-0352-497f-9733-dcbd.jpghttp://forums.y-blocksforever.com/uploads/images/e9687223-272f-42af-bb6c-0a8a.jpg
bobo1
Thanks for you answers , you have a very very nice engine Oldmics I already see it on the Hamb if I'm right you are put it in a f100
How much you want for your air cleaners
Oldmics
Please contact me thru a P.M. or at
Oldmics@Yahoo.com
about the air cleaners.
The M 335 came out of and went back into a 57 Merc Commuter wagon. Pic below.
http://forums.y-blocksforever.com/uploads/images/c27d32e8-f434-4462-8676-6589.jpg
Your Commuter looks nice, Oldmics!
What was the gauge ceiling Merc used for the Turnpike Cruiser distributor driven mechanical tach?
What manual transmission are you using behind the M 335 engine?
Regards,
Oldmics
N.S.
Thanks for the kudos !!!!!
Not quite sure what you mean regarding the "gauge ceiling" - so I don't know how to respond.
Tranny is a beefed T85 from Bill Stropes shop who originally did all of the M 335 builds.
Oldmics
bobo1
Very nice car Wink What sort of linkage did you use with it and I would like to konw if is it ok with my msd distributor ?
