T85 overdrive
Posted By 62bigwindow 9 Years Ago
62bigwindow
Posts: 884, Visits: 14.3K
WTB a T85 overdrive for my 56.
Durham Missouri
Y block guy
Supercharged (104 reputation)Supercharged (104 reputation)Supercharged (104 reputation)Supercharged (104 reputation)Supercharged (104 reputation)Supercharged (104 reputation)Supercharged (104 reputation)Supercharged (104 reputation)Supercharged (104 reputation)
Posts: 42, Visits: 1.4K
Hi, I have one out of my 56 vic, it was rebuilt for $1,110.59, WORKS great,  went to a 5 speed.  Open to offers located in wa state
62bigwindow
pm sent
Durham Missouri
62bigwindow
Still looking for one.
Durham Missouri
62bigwindow
Bump
Durham Missouri
56vikki
Turbocharged (63 reputation)Turbocharged (63 reputation)Turbocharged (63 reputation)Turbocharged (63 reputation)Turbocharged (63 reputation)Turbocharged (63 reputation)Turbocharged (63 reputation)Turbocharged (63 reputation)Turbocharged (63 reputation)
Posts: 24, Visits: 324
I have one rebuilt in 2013 about 500 miles on it.850.00.im in nj.
62bigwindow
Still looking.
Durham Missouri
Saw this on eBay.  This is not my listing.
Comments:
- helical trans main shaft makes it a T-85 not a T-89...
- don't be mislead by the T-89 casting number on the 9 bolt curved side cover, trans is a T-85...
- T85C-1A casting number on trans case makes it a T-85 for sure...
- 10 spline clutch input shaft makes this '57 and earlier application, I think... Ford went to 23 spline in (?) '58 (?) and up
- 16 spline output shaft... the yoke for this is tough to come by, out of production LONG time...  '55, '56, '57 Mercury standard AND MercoMatic trans applications use this yoke!
- later (?) '58 up (?) T-85s use a 31 spline output shaft...
- this trans has both the solenoid and the governor... are they 6 volt or 12 volt??? '55 Merc T-85 ODs were 6 volt...
- CA eBay listing... shipping of these trans is not cheap... weight is ~150 lbs.
- seller comments on reverse gear wear... several new replacement reverse gears for the T-85 are regularly listed on eBay
Hope this helps.   Smile
Click the link below.
http://www.ebay.com/itm/221886190778?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AI
62bigwindow
Thanks for posting that. I found one but it is out of a 62 so that means my new clutch won't work as it is a 10 spline. So if I read that right I need to get a different clutch disc.
Durham Missouri
Me thinks so...BUT... I've given up swearing to anything.
I saw one later T-85 (based upon the 31 spline output shaft) that had a 10 spline input shaft.  I suspect that the input shafts can be interchanged and may have have been swapped in  a rebuild...  Don't know for sure.
Trying to help, but not an expert on the subject...
Best Wishes.   Smile
