T85 overdrive
Posted By 62bigwindow 11 Years Ago
62bigwindow
Posts: 884, Visits: 14.3K
I appreciate all the help. I just got done looking and it does seem that info is correct. I assume I can just get a different 10 " clutch disc and the pressure plate will still work?
Durham Missouri
Ford used both 10 inch and 11 inch clutch disc / pressure plate applications with the two input shaft spline configuration that we've been talking about.
The flywheel you're using will determine which size clutch disc and pressure plate you're going to use.  The stock FoMoCo y-block flywheels I've encountered were drilled for one size pressure plate or the other, not for either or.
Hope this helps.   Smile
Last Active: 9 days ago
Posts: 1.9K, Visits: 195.0K
I've always been able to find a disc with the right splines, but IIRC, one time there was a hub interference problem. Just went to a different brand, or style, or something. Recall isn't my strong suit these days.
denny
Turbocharged (64 reputation)Turbocharged (64 reputation)Turbocharged (64 reputation)Turbocharged (64 reputation)Turbocharged (64 reputation)Turbocharged (64 reputation)Turbocharged (64 reputation)Turbocharged (64 reputation)Turbocharged (64 reputation)
Posts: 27, Visits: 239
still trying to figure out all this web sight stuff, so forgive me if iam in the wrong AREA ,DO YOU STILL HAVE T-85 FOR SALE?
Denny.  You're in a different thread than the last time you wrote asking about this topic.
I had email communication with Royce Brechler last week on 10/22 .  Royce wrote:
I have a non overdrive T-85 . It has part of a shifter attached...  not sure what brand but it is missing the shift lever. I would have to pull the cover off to check how it looks inside..  It is missing the driveshaft yoke.
I'd recommend that you email Royce at   brechlrl@charter.net   and ask him:
- what the input shaft spline count and the output shaft spline count is for the transmission.  The 30 something output spline yoke is easy to obtain. IF it's a 16 spline count spline  I'm pretty sure I can get one for you.  I expect my cost for this hard-to-find used piece will be 45 bucks plus USPS postage from a fellow East of me.
- consider asking Royce to pull the 9 bolt curved side cover and inspect the condition of the cluster gear, the teeth on the first & reverse gear, and the condition of the teeth on the reverse idler gear.
- Also, ask Royce for the raised Borg Warner part number on the transmission extension housing.  IF I know that ID number, I can look-up what Ford or Mercury application the transmission came out of.
- After Royce has told you how the gears inside of the transmission look, ask him how much he'll sell it to you for IF you like what he says.  The 3 speed T-85 he had advertised on here 3 years ago, he was asking $150 for.  I suspect that did not include the shipping expense.
Keep me in the loop on how this unfolds and I'll help you as much as I can.  Smile
