292 rebuild
Posted By unibody madness 10 Years Ago
unibody madness
Posted 10 Years Ago
Supercharged (129 reputation)Supercharged (129 reputation)Supercharged (129 reputation)Supercharged (129 reputation)Supercharged (129 reputation)Supercharged (129 reputation)Supercharged (129 reputation)Supercharged (129 reputation)Supercharged (129 reputation)
Posts: 53, Visits: 1.7K
*NOT MINE*
Found this on another site:
http://orlando.craigslist.org/pts/4954381727.html
I think it might be a decent deal for someone closer
I was interested so I asked some questions.
Looked them up and they seem reputable. Hate to see a shop lose a bunch of money on a bum deal so I posted my results here
Freight,distance,and time since rebuild kind of killed it for me, I have been told it is really easy to wipe a cam if it sits too long between rebuild and break-in.
"quote"
This engine came into our shop in Feb 2009 for a complete rebuild. It was bored out .040 & diamond honed, fitted with new pistons & rings, resized rods, ground crank with new rod & main bearings, new camshaft & lifters, re-manufactured heads, new timing, new oil pump & all new gaskets. This 292 came out of a 1964 F100. The owner never came back to claim his engine. It is sitting on a pallet still wrapped in plastic.
---and---
The engine has never been run, It came out of our engine room after the rebuild, we spin test all our engines to record compression, set valve lash & record oil pressure. It is dressed with the oil pan, valve covers, intake manifold & the water pump. We do not have the flywheel or distributor.
I am prepared to let it go for $1600
Posted 10 Years Ago
Last Active: 8 hours ago
Posts: 7.4K, Visits: 205.7K
Assuming $400 or less for freight, this would be quite a deal for someone wanting a stock built engine.  Adding a better than stock camshaft, a four barrel intake and carburetor would still make this engine a good buy.
