'E' Bird Set-up
Posted By NoShortcuts 10 Years Ago
Posted 10 Years Ago
This is a q-u-a-l-i-t-y set-up.  Not mine; known the owner since the early '70s; he owned the car this came off before I knew him.  IF I needed a dual quad set-up for an automatic '57 'Bird or if you did, I'd recommend it unconditionally.  Not a fix-'em-up project.  Complete, No disappointments, No surprises.  ALL original Ford parts.  Everything correct... throttle linkage, carburetors, fuel lines; valley pan, air cleaner, 'E' ignition distributor.  No reproduction components from anyone.  Does not have the garbage can fuel filter unit.
Listed on eBay.  Item auction number to search is 331521875761
Read the ad, see the pictures.
Consider calling the owner direct.  Phone 315-446-5064 Eastern time, Central New York.  Ask for Ron.  Tell him that you're a Y-block Forum member.  He's a car guy who has forgotten more about this stuff than I'll ever know!  Smile
or click the Internet address    http://www.ebay.com/itm/331521875761
slumlord444
Posted 10 Years Ago
Last Active: 5 days ago
Posts: 1.2K, Visits: 137.8K
Nice setup. Chrome on the air cleaner is not correct but the rest looks right. Air cleaner was Argent. The hold downs are really hard to find. Would like to have a set.
Posted 10 Years Ago
Have been told that the 'E' 'Bird intake manifold hold down 'clam shells' are identical to those used on '54 Ford 239 and '54 Merc 256 engines...
Hope this helps, Slumlord.  Smile
carl
Posted 10 Years Ago
Last Active: 9 days ago
Posts: 1.2K, Visits: 20.6K
slumlord444 (4/6/2015)
  I might have a set of manifold hold down clamps for a 256 merc,I will check today carl
