292 pulley question
Posted By jeves 11 Years Ago
slumlord444
Posts: 1.2K, Visits: 137.8K
You can also put washers behind the crankshaft pulley, Ended up doing that on my Bird. Pressing the hub back on the water pump may be a better idea. There is a spec for the distance form the front of the water pump shaft to the front of the hub and mine was actually off. Did not have a press so shimmed the crank pulley. Finally got it all lined up right or very close.   .
Last Active: 7 hours ago
Posts: 4.6K, Visits: 39.3K
There are several different sizes of water pump pulleys. They vary in diameter and depth. If you have any Y-block friends see if they have a stash of pulleys. You should be able to find something to work. Chuck
