How much power are you making with what setup???
Posted By babor 11 Years Ago
RB
Posts: 662, Visits: 16.7K
I just milled a pair of G heads .030  They cc'd out at 63.
Last Active: 11 hours ago
Before attempting to mill any Y cylinder head, be sure to measure the pads at the outer edge under the spark plugs.  These are typically 1.000” as delivered from the factory and anything measured that’s less than this will be a good indication of the amount that those particular heads had being previously milled.
Y block Billy
Posts: 1.6K, Visits: 5.2K
Ted, 1.4 times .050" = .070"
.54 X .050" = .027 I thought it was somewhere around there.
55 Vicky & customline
We've been going at the static compression ratio thing, Babor.  As you likely know, your engine's dynamic compression ratio really determines the maximum static compression ratio you can get away with for the fuel you plan to use.
One of the references that has been previously suggested here to use as you contemplate your build is the dynamic compression ratio calculator at
http://www.wallaceracing.com/dynamic-cr.php
Dynamic compression ratio is a measurement of the swept volume of the cylinder and combustion chamber area when the actual compression of the air-fuel mixture commences when the intake valve closes after bottom dead center on the compression stroke compared to the volume of the area above the piston when it is at top dead center in the cylinder.
NOTE:  the volume above the piston in the cylinder when it is at top dead center includes:
-    the recess of the piston in the cylinder bore below the block deck
-    the cylinder head’s combustion chamber volume
-    the volume of the area bounded by cylinder head gasket thickness
It has been amazing to me how WHEN the intake valve closes after BDC so significantly affects how high a static compression ratio my engine will tolerate.  With the information I've previously gotten from Ted Eaton, for my purposes (street and highway) and with 91 octane pump gas, I look to stay at 8.0:1 dynamic compression maximum for reliability purposes (no detonation) due to the quality of gas in my area.
Regards,
YB Billy: re the intake side milling. I got confused on that one also. Re read his post. Ted said to apply the 1.4 ratio cut "after" 0.030, not on the total cut.. However, your method comes out about the same..
aussiebird
Hitting on all eight cylinders (13 reputation)Hitting on all eight cylinders (13 reputation)Hitting on all eight cylinders (13 reputation)Hitting on all eight cylinders (13 reputation)Hitting on all eight cylinders (13 reputation)Hitting on all eight cylinders (13 reputation)Hitting on all eight cylinders (13 reputation)Hitting on all eight cylinders (13 reputation)Hitting on all eight cylinders (13 reputation)
Posts: 3, Visits: 8
Hi all
l recently built a y block with mummerts advise and expertise these yblocks are pretty good and very high reving engines
forged pistons mummert suppled rods cam heads manifold 750cfm dp holley c4 conversion and a 9inch LSD and l have to say lm
impressed and they sound better than any other V8 out there http://forums.y-blocksforever.com/uploads/images/06dbc9d9-b9a2-46ad-b7b4-91e1.jpg
