Mummert intake + carb spacer
Posted By slick56 12 Years Ago
slick56
Question Posted 12 Years Ago
Last Active: 3 Weeks Ago
Posts: 463, Visits: 4.5K
Finally have enough spare to order a Mummert intake. Currently running a B intake with 2" spacer;
what manifold would i order, the standard or the +1/2" high rise? Will 2-1/2" above stock be too high
for torque or power?
Plenty of room under the hood with 60's air filter assy.
Thanks, Al.
South Australia
Here’s the link to the article that was in Y-Block Magazine regarding 2” tall spacer testing on a Mummert intake.  Spacer design would appear to be critical.
http://www.eatonbalancing.com/blog/2012/09/29/carburetor-spacer-testing/
slick56
Thanks Ted, quite an eye-opener!
I would not be making much more than half that horsepower tho...
the tapered spacer would add a few neddies, but do
i opt for the standard or hi-rise Mummert initially?
the cam is a Y-270-S, adv. duration 272*. @ .050 224*, .440 lift
C heads with 1.84 in and 1.50 ex, mild porting, milled .025, decked,
cast 292 +.040 pistons, I beam rods, balanced, 62 dizzy,
pertronix, 16* initial, all in 36* @ 2200, 600 holley vac sec,
runs well but the 6litre scrubs are giving me a hard time  BigGrin
South Australia
slick56 (12/27/2014)
....... but do I opt for the standard or hi-rise Mummert initially?
Unless you have a ’55-’57 Thunderbird, the general rule is to opt for the hi-rise manifold.  John can correct me on this if I’m wrong but I believe the high rise manifold is only about ¼” taller than the Thunderbird specific intake.
