Tom Drummond's Hot Rod Lincoln
Posted By RB 11 Years Ago
RB
Last Active: 4 Months Ago
Posts: 658, Visits: 16.7K
I just finished helping Tom freshen up the 368 Lincoln from his 57 Ranchero.  We hope to have some more pictures, video, and good numbers from next weeks dyno sessionhttp://forums.y-blocksforever.com/uploads/images/31794055-c201-443f-b90f-e1ee.jpghttp://forums.y-blocksforever.com/uploads/images/8acb83cd-d7d2-47b0-9abd-7c94.jpg
Posts: 1.9K, Visits: 194.9K
That's too cool for words. Several years ago, at Del Mar IIRC, there was a 57 with a similar set up with the dual quads on a 312. I have a similar bracket for the supercharger for a 292 I got from C Conley years ago. But a Lincoln? How cool. Does the dual drive system still work for high boost?
Last Active: 23 minutes ago
Posts: 4.6K, Visits: 38.5K
Nice looking Lincoln. Can't wait to hear it run. Chuck
Y block Billy
Posts: 1.6K, Visits: 5.2K
I think Commander Cody wrote a song about that engine!
55 Vicky & customline
Oldmics
Posts: 710, Visits: 78.1K
So I gotta know more about that clutch setup. Can Tom elaborate on that ?
I had a hell of an expensive time getting the clutch stuff right in my 368 wagon. Would really like to know how Tom did it!
Oldmics
RB
Tom is running a C-4 automatic behind his. I have a couple 368's with stick trannnys.  Unless you are lucky enuf to have some of the rare factory parts it can be pretty involved.
Oldmics
So the bell housing on the pictured engine is only for testing or mockup?
I have the "rare factory parts" (or most of them) and it was still a bitch to get right.
Thanks Royce
Oldmics
RB
I just put it on there to get the engine started... We will also use it to hook to the dyno.. Tom used an automatic bell for the C-4 conversion
What  have you done to cure the head gasket issue? Sure looks neat.
RB
Frank  we dropped compression from a static 10.5 to 8.5 . Careful gasket prep and switched to a Best gasket. Increase bolt torque and careful re-torquing.. Changed to a cam with less cranking pressure...  Pray
