replacement dizzy
Posted By bayboy 11 Years Ago
bayboy
Question Posted 11 Years Ago
Normally aspirated (35 reputation)Normally aspirated (35 reputation)Normally aspirated (35 reputation)Normally aspirated (35 reputation)Normally aspirated (35 reputation)Normally aspirated (35 reputation)Normally aspirated (35 reputation)Normally aspirated (35 reputation)Normally aspirated (35 reputation)
Posts: 16, Visits: 1.1K
has any boby fit or modified a dizzy from a 351 Windsor sb with electronic ignition for a yblk  ??? or would it even work  or does it rotate in the wrong direction
Last Active: 5 hours ago
Yep, it's been done.  Do a search for duraspark and quite a few topics should come up.  Here's one to get you started.
http://forums.y-blocksforever.com/Topic5574-1.aspx
2721955meteor
Posts: 927, Visits: 190.0K
Have done several they work great,as the site states later y block dist are easey as dura spark stuf swaps easy.. i have converted the early style(1st type with cent advance) buy useing the upper portion of the 302 cuting the shaft and welding to the y shaft as the 302 shaft is 2 short.it was more work than makes sense. turne 1in of y shaft down and driled 302 shaft presed together  then miged th joint..was telling mark about my  eforts and he told me about the site and we have since converted  3 of them the easey way.The rewards of this site are excelent, especialey great when the experts put on drawings and wireing inst.  cliff
lyonroad
Posts: 703, Visits: 3.1K
The expert that Cliff is referring to is Steve Metzger aka "Greenbird".  If you want to do a Duraspark conversion search out his posts.  You won't be disapointed.
Mark
1956 Mercury M100
1955 Ford Fairlane Club Sedan
Delta, British Columbia
Kahuna
Posted 10 Years Ago
Posts: 471, Visits: 2.4K
What is the advantage to this conversion?
lowrider
Posted 10 Years Ago
Posts: 479, Visits: 10.9K
I converted mine to Duraspark on my 57 Ford 292 a few years ago. Starting and idling were greatly improved on mine and runs great driving down the road. I picked up the factory wiring loom when I gathered up parts to do the conversion so the installation looks almost factory installed. Haven't had a bit of trouble with it out here in the AZ. heat. X2 on Greenbirds knowledge on this conversion.
Posted 10 Years Ago
The biggest benefit, if you stick to Duraspark, or Duraspark / GM Hei hybrid, is that you can find replacement parts practically anywhere.
You can also use the Duraspark distributor components to trigger pretty much any aftermarket ignition box.
